Old 06-27-2017, 02:32 PM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
Default **NEW PRODUCT!!** 1964-1965 GTO FULL REAR QUARTERS!!!!
Now available 1964-1965 GTO full rear quarters. Call 1-800-421-2637 to place your order for J183SL & J183SR!!
Name:	64-65 quarters.jpg
Old 06-27-2017, 06:15 PM
GTO1's Avatar
GTO1 GTO1 is offline
How much?
Old 06-27-2017, 07:23 PM
tempest1964's Avatar
I just copied and pasted to search, $569.
Old 08-05-2017, 11:00 PM
eric65's Avatar
eric65 eric65 is offline
Default Pix of these from Norwalk
New 1/4's are in at Norwalk
Check out Metal seemed good thickness
I think the contour of the crease towards the door gets larger as it gets to the door
Thoughts or views?
ID:	460518   Click image for larger version
ID:	460519   Click image for larger version
ID:	460520   Click image for larger version
Old 08-06-2017, 12:02 AM
64speed's Avatar
64speed 64speed is offline
I called AMD the day they became available and scheduled my appt for the AMD installation center. Mine will be going on in December because they have a 6 month wait list so unless someone is hanging them themselves or having an outside body shop do it then mine will be the first installed. At least they will be at AMD. I am having both quarters the trunk floor inner and outer wheel houses and filler panel plus one floor pan installed for right at 6000 parts and all
Old 08-06-2017, 09:38 AM
War eagle War eagle is offline
Thoughts or views?
Does the crease from the wheel opening back look uneven also? That blend line seems to grow in the middle in the 2 different views of that area making it not just the camera angle. Other wise glad to see something new available. Now if we could get some doors, deck lids and tail lamp panels it might be possible to make convertibles from doner 4 drs of most "A" body platforms. (mostly joking)
