Old 04-22-2020, 01:32 PM
Mark G Mark G is offline
Default Throttle position sensor for Dominator
I have a Bob Book dominator I need a TPS sensor for my new Nitrous Progressive Controller & my new data logger What are you guys using ..Thanks
Old 04-22-2020, 05:01 PM
Nobody ...lol
Old 04-22-2020, 05:51 PM
Scott65's Avatar
Scott65 Scott65 is offline
Does it have a lug on the throttle shaft to drive a tps?
Old 04-22-2020, 06:12 PM
JD's Avatar
JD JD is offline
This what we did. You need to be good with a drill though so I have my fabricator do it for me. I use it with a Haltech VMS ECU.
Name:	Dominator TPS Arm.jpg
Jim
71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas
Old 04-22-2020, 06:22 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I have wondered if you can mount a TPS on the gas pedal. This would make it easy to test different carbs / intakes.
Old 04-22-2020, 06:27 PM
Scott65's Avatar
Do you then use one of the cable type tps with that arrangement?
Old 04-22-2020, 06:54 PM
JD's Avatar
JD JD is offline
The only problem with that is if the cable slips or brakes and the throttle blades close but the nitrous stays on bad things will happen.
Jim
Old 04-22-2020, 07:03 PM
No I don't think it does
ID:	538149   Click image for larger version
Old 04-22-2020, 07:04 PM
JD's Avatar
JD JD is offline
Sorry I should have added pictures of that before.
The bracket was fabricated and the sensor is Standard Motor Products TH36.
The lever arm on the sensor goes into the hole on the top of the arm that is mounted on the throttle shaft.
ID:	538151   Click image for larger version
Name:	TPS Front.jpg
Jim
Old 04-22-2020, 07:07 PM
JD's Avatar
JD JD is offline
To mount the arm as I showed above you need to remove the dust cap on the passenger side of the carb and then drill and tap the throttle shaft for a spacer and arm. Make sure to use Loctite on the small bolt for final assembly.
Jim
Old 04-22-2020, 07:10 PM
Where do I get the kit drilling and taping not a problem I just need the parts or did you make every thing.Thanks
Old 04-22-2020, 08:14 PM
Scott65's Avatar
https://www.jegs.com/i/Speedmaster/7...BoC1BgQAvD_BwE
Something like this may help with fabrication. Also would allow the use of the more common gm tps it looks like. I've never used one.
Old 04-22-2020, 08:39 PM
charlie66's Avatar
Heres one ...
http://blog.innovatemotorsports.com/...-applications/
My Half AN Injun.....
The Following User Says Thank You to charlie66 For This Useful Post:
Old 04-22-2020, 09:54 PM
Well I got it done tonight popped off that dust cover like you said drilled and tapped thank you JD also thank you everybody else who contribute to this post stay safe wash your hands sorry for the sideways picture
Old 04-22-2020, 09:59 PM
Originally Posted by charlie66 View Post
Thank you Charley I talked to that guy tonight he told me to call back in the morning That is the one I am using ..
Old 04-22-2020, 11:16 PM
JD's Avatar
JD JD is offline
The arm from Innovate Motorsports is for a 4150 and had a flat spot on the ID which matches the throttle shaft which sticks out past the edge of of the base plate. I use one of those on the 4150 I swap on.
The arm and spacer were fabricated. I purchased the TPS from RockAuto. Here is a drawing of the arm that we made.
Name:	TPS Lever Arm.jpg
Jim
The Following User Says Thank You to JD For This Useful Post:
Old 04-23-2020, 12:31 AM
Well I new that before I ordered it...lol I make my own arm based on your drawing JD ..Thank you so much... I will see if I can cancel my order
Old 04-23-2020, 12:43 AM
You have any dimension on this bracket JD
Old 04-23-2020, 01:11 AM
JD's Avatar
JD JD is offline
Unfortunately I don't since I didn't make that piece myself.
Jim
Old 04-23-2020, 08:23 AM
Ok NP I did cancel my order so making every thing .. Just got to find a wire harness ..Thanks JD
Thread Tools
Display Modes
