1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following User Says Thank You to AG For This Useful Post: | ||
I went to the dark side..I have 373's now...hoping to get er down to 10.4's next year.
Filled block
IMO filling the block is well worth doing for strengthening.
As far as cooling volume I don’t believe that’s as important the benefits of added strength. Many disagree of course and I’m fine with that. The “cooling” issues some claim can easily be offset with an oil cooler which is a good plan anyway. I have a friend that had a 482 bbc (.100 over 454) The block stabilization was needed for the overbore again IMO street/strip driven off and on for ten years and now it’s back in a different strip dedicated car… Only issue was after a couple hours the oil temp needed addressing, and an oil cooler solved that even in hotter the hades Louisiana. |
I have a 455 (473.333c.i.) in my bracket car and the guy that did this engine initially did not use a torque plate this was in 1995. This was a low 12 second street car then and over the years has evolved into a low 10 second bracket car. During one of the upgrades I hard blocked it up to the bottom of the water holes in the front of the engine. This car always ran below 180 even on very hot days when I ran it on the street for quite a few years. As a drag car it can go rounds with no cool down time so hard blocking it I believe made the car run cooler and I never check oil temperature but never had a problem. I am still running the same block rods and pistons but have changed heads, crank and cam a few times over the years.
Tim Corcoran |
I have remember Tom V talking about some organization that is as testing different oils. He said the Redline stuff was the best on the market ( or something like that). My thought is to run a good filter and synthetic oil, and not worry!!! My engine builder friend was supplied Redline oil products, for 2-3 years, when he was having some success. He told me their product is as second to none!
"Some time ago, here someone here postulated that some of the coolant in a Pontiac block was not really needed, or maybe I should say, not helping cool the block."
Within the link in my post #4 had reference to that. Here was that information... It actually makes the floor of the water passage smoother and assists flow and heat transfer heat better. And that area down at the very bottom gets very little water circulation anyway on a un-filled block (some suggest a 'dead' area). It is correct it will not effect water temps to any great degree after filling and some actually report it runs cooler. The question comes up, can I suspect the Oil Temperature will be hotter with the Half-Filled Block. This has always been a subject of controversy. I was at a Pontiac 'seminar' many years ago and that subject came up in an open discussion and also confirmed by a old-school PMD racer. Among other noted individuals on hand was Arnie Beswick, Pete McCarthy and Jim Butler. If memory serves me right it was one of those three individuals that agreed. That said, it was noted it did not have a major effect. And if memory serves me right again there was no one in attendance during this open discussion to offer their objection. And yet I know of others that saw no difference in oil temps before and after filling as measured on their oil temp gauge. Bottom line in many opinions don't be overly concerned and by all means install a oil temp gauge. Comments from Pontiac Dude.... How is oil temp effected by the bottom 2" or so of the filled block. If that was the case then I would not install windage trays and crank scrapers in the engine to keep the oil in the pan. Also the most of the heat is in the head and top of the cylinder where all the power is made when that spark plug fires. Related...... Taken in part from Jim Butler comments, Q&A section, PE magazine March/April 1997: They built two engines for Rodney's '82 T/A street car. Both engines had 455 blocks. One was filled and the other wasn't. The filled block ran 10 to 15 degrees cooler than the unfilled block. It was reported upon tear-down and inspection, the cylinder walls on the unfilled block were seen to be scratched and scored from excess friction. When measured with a dial bore gauge, it was found to be out of round. The filled block was smooth and bore round. He confirmed you do not lose significant coolant capacity by filling the block. However, the difference in the amount of friction is much improved. .
A half filled block indeed produces more even bore temperatures, so yes they stay true to being round and with little taper far better, much more like they are when they are removed from your chosen shops bore and hone machines.
Be done , and off the fence and do it!!
Another tid bit, David Butler recommends a filled factory block when using a 4.5" stroke crank. And this was not dependent on a race only situation.
My filled blocks (Two The Water Pump) run cooler then my,
nonfilled motors; I have two of them, 474 stroker+406. GT |
As a point of reference - this is a pic of my 2019 5.3 Gen V block. Note how the outside of the block conforms to the cylinder up to the oil gallery, then is jacketed.
