Old 01-24-2024, 03:54 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default Oil drainback on aluminum heads?
I've been doing some serious cleanup on my new Black Friday Special SM heads which really got me to thinking, is there something we can do to help get the oil back in the pan?
This head is approximately 45 degrees and you can see how much oil could collect on the edges before the oil is high enough to drain back.
I could be over thinking this, any thoughts??
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 01-24-2024, 04:07 PM
Steve C. Steve C. is offline
We have done the same as post #6 here....
https://forums.maxperformanceinc.com...ck+drain+holes
Also oil hole radius and polishing.
The first generation Edelbrock heads were notorious for issues.
Old information here:
The Following 2 Users Say Thank You to Steve C. For This Useful Post:
Old 01-24-2024, 04:54 PM
mgarblik mgarblik is offline
I work and massage the drain troughs/holes that already exist. Haven't worked on any SM heads, but since they are a replica/copy of the Edelbrock heads, they should behave the same. I widen and polish the trough all the way to the spring seats, polish and enlarge the entrance of the hole making it more of a funnel shape. Lower it a little. Just removing all the sharp edges, smoothing and polishing the drain path, makes a big difference.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 01-29-2024, 08:17 AM
Tim Corcoran's Avatar
I bought my 330 CFM eheads from Dave at SD Performance. Although they have the earlier combustion chamber design Dave did modified the drain back holes to improve drain back. I think the need for putting on the external hoses for improved drain back may be somewhat dependent on the RPM that your engine is running at. Because of my cam specs my converter stall is 4,400 and I shift at 5,600 and shifting any higher does not improve ET or MPH. So at my RPM I don't believe I have any oil starvation issues. If I was shifting at 7,000 or higher then I would definitely install the drain back lines or get an accumulator to prevent oil starvation.
Tim Corcoran
Old 01-29-2024, 03:50 PM
A restricted pushrod will slow the flow to the top also. I put drain back lines on the race engines I do.
The Following User Says Thank You to chiefbigb For This Useful Post:
Old 01-29-2024, 04:27 PM
Johnny406's Avatar
I'm playing with this some more, here are a few pictures. I couldn't find any playdough so I used a piece of cookie to illustrate what I'm thinking.
At a 45 degree angle and NOT accounting for engine tilt or enertia during acceleration/braking, the ruler give an idea how high the the oil drain holes are.
I was thinking of cutting a groove in the valve cover bosses to smooth out the oil draining from front to back. I would also put in some high temp putty or tap and plug those two freezeplug holes and some putty at the back of the head around a couple of tapped screws to eliminate the void and help get the oil back to the drain back line like Steve C. suggested on his post represented by the black dot.
Name:	SM Oil Front.jpg
ID:	627475   Click image for larger version
Name:	SM Oil side.jpg
ID:	627476   Click image for larger version
Name:	SM Oil Back.jpg
Old 01-29-2024, 05:34 PM
Dragncar Dragncar is offline
I run .030 restrictors on all my solid stuff and has served me well.
The High Ports currently in service look to have fine oil return-drain back qualities.
No where for oil to puddle up.
Old 01-31-2024, 11:58 PM
Johnny406's Avatar
Here's what I did to reduce the resistance and allow the oil to drain to the back of the head. The dot is approximately where I'll plumb a line from there straight to the pan. Probably a bit overkill but... I have time to kill anyways.
ID:	627658   Click image for larger version
ID:	627659   Click image for larger version
Old 02-05-2024, 04:53 PM
Johnny406's Avatar
A bit more progress. This is a 3/8" barb fitting, I'll be using 1/2" barb fittings (1/4npt) along with 1/2" braded line. I also ordered some 1/2" bulkhead fittings for the pan.
Old 02-05-2024, 06:46 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
How about steel bent lines over your headers instead of rubber please
I love the work just don’t want to see it go up
In smoke literally
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 02-05-2024, 08:59 PM
I use the Teflon steel braided lines with crimp.on fittings. No rubber. Weld in bungs to the pan to accept fittings. A 90 will usually work on both ends
Old 02-13-2024, 10:52 PM
Johnny406's Avatar
Still doing some mockup work on this project, I had to wait for some 90 degree bulkhead fittings to get here. No worries, I'm not using this clear vinyl tubing for the finished project. I'll either use oil cooler hose or perhaps 1/2" aluminum fuel line and compression fittings. The engine is rotated pan up on the stand, I rotated and cropped the 2nd and 3rd picture for clarity... no Newton defying here LOL.
ID:	628577   Click image for larger version
ID:	628578   Click image for larger version
Old 02-14-2024, 09:02 AM
chuckies76ta's Avatar
Just an opinion here. Get someone to weld fittings on the oil pan for you and tap the heads for fittings and use a teflon inner liner hose with braiding on the outside. Get the hydraulic shop to put ends on the hose for you. I know it's a bit overkill but no worries after.
I got my lines done by a company called Greenline hose here. I welded this fitting to the oil pan. and used a 90 degree fitting to position hose.
https://www.summitracing.com/parts/s...7b?seid=srese1 You can get these in steel cause oil pan is steel.
ID:	628586   Click image for larger version
The Following User Says Thank You to chuckies76ta For This Useful Post:
