Old 12-29-2009, 02:50 PM
cor1cor cor1cor is offline
Default pontica sunfire 1998
im trying to change my front door speakers and i wanna know if anyone know how to take the doors off
Old 12-29-2009, 05:23 PM
judgethis judgethis is offline
Remove the upper triangle trim piece (held by a screw). Remove the inside door handle bezel. Remove door lock switch and power widow switch if equipped. There are a few screws along the bottom of the door panel and two screws from the door arm rest. Then take a long screw driver or if you have a door panel removal tool and pry panel away from door. Now you can change your speaker!
Old 01-01-2010, 11:23 AM
how do you take the wndow roll handle off
Old 01-01-2010, 02:40 PM
There is a "U" shaped clip that hold it on to the regulator shaft. You can buy the tool to help remove it from any auto parts store. The tool is anly a few dollars. The instruction will be with the tool.
