Old 12-21-2023, 10:10 PM
VCho455's Avatar
VCho455 VCho455 is offline
Default Looking for valve relief sizes on TRW/Sealed Power pistons.
The 389 I just picked up came with a detailed parts list for its rebuild. It lists the pistons as Sealed Power L-2269-030. I know they're .030 over but I am wondering about the valve relief size and if they are going to work with later heads.
I came up with information on clearances and dishing them when I did a search.
Thanks in advance for any information.
Old 12-21-2023, 10:20 PM
JB Eng Wis JB Eng Wis is offline
According to my old 2000 Speed -Pro catalog is says -3cc
Old 12-22-2023, 01:17 AM
VCho455's Avatar
Thanks for the quick reply. The paperwork with the engine is dated 2004. I think you have provided the answer I needed.
Old 12-22-2023, 01:18 AM
VCho455's Avatar
Thanks for the quick reply. The paperwork with the engine is dated 2004. I'm feeling confident you have provided the answer I needed.
Old 12-22-2023, 07:01 AM
steve25 steve25 is offline
The valve notches in those 389 Pistons due to the earlier heads 20 degree valve inclination angle will be ( 1) deeper. ( 2) not as wide, ( 3) in the wrong place for the later heads 14 degree inclination angle.
If your going to run iron or aftermarket heads with about a 72 CC chamber then your going to be limited to about running no more then about .440" lift depending on a few build detail factors.
Old 12-22-2023, 04:40 PM
VCho455's Avatar
I was afraid that was going to be the case. Looks like I'll be doing some piston machining. I believe this poor engine has suffered the fate of being rebuilt by someone who didn't understand how to build power in a Pontiac.
Thanks for the information.
Old 12-22-2023, 06:24 PM
So I guess your pistons look like these as found on EBay?
If so then each valve notch looks like 3 CCs for a total of 12 CCs.
ID:	625455   Click image for larger version
Old 12-23-2023, 03:17 PM
VCho455's Avatar
I haven't pulled a head yet to confirm. The engine was said to ping badly. It's a .030 389 with 092 heads and a xr276 HR cam with 1.6 rockers.
