Bob,or Tom,what if anything can be done to address porosity with alu?I know its has been and maybe still is a problem,also does alu have more core shift problems than iron?NBD on a dry block but is on a water block.Tom
Thanks for helping Tom.
We are having made 20 crank shaft heat sinks and 20 valley pan heat sinks made to cool the block after pouring. We will pass a cooling water thru them to cool the pour. This thing will be like jellow for a long while after it is poured and we need to cool it fast. We will cut up many blocks as we did before to not guess as to what is happening, but know what is happening inside.
Bob C. Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads Boss Bird Funny Car Best pass to date 08/06/2016 6.027@231.64 Allpontiac Big Chief Aluminum Engine Block http://www.AllPontiac.com |
Ok, I'll ask the question noone else has asked: Cost???
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by FantomPoncho:
Ok, I'll ask the question noone else has asked: Cost??? <HR></BLOCKQUOTE> To be anounced in December, like Bob said.
I bet it will be more than one of those classic $100 blocks, LOL.
Systems under stress fail catastrophically |
AWESOME!!!
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Mo:
I bet it will be more than one of those classic $100 blocks, LOL. <HR></BLOCKQUOTE> And unlike that block, it will be stronger AND repairable...oh, and lighter too.
Agree that the key for core shift and exclusions
is a proper pour with the correct cooling strategy. The porosity issue is more prevalent on the aluminum blocks as you mentioned Tom S but can be worked out with the right thought process. If the IA-2/Butler AL blocks are cast by the same source as before they should know how to do this having worked with AL in the past on other projects. Tom V. I will speak with our block guy to see if there are any other magic bullits out there too.
Tom and Gang, It will be casted by our casting house. And machined by a Roush Industries or one of their subcontractors.
TA Bob, will it be offered in both tall deck and standard deck?
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. 8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08 |
Now Kauffman is a dealer for the IA II blocks?
I would definately go with an aluminum block over the $100 stock block. Why?? Because it's repairable. An explosion would not be nearly as expensive. I suppose if I were to put them in order of priority, it would be:
1. Aluminum Block 2. Stock Block 3. IA2 |
I would definately go with an aluminum block over the $100 stock block. Why?? Because it's repairable. An explosion would not be nearly as expensive. I suppose if I were to put them in order of priority, it would be: 1. Aluminum Block 2. Stock Block 3. IA2 <HR></BLOCKQUOTE> You're speaking for a blown nitro' application, correct?
Oh I have seen aluminum V-8 blocks that have been un-repairable after an explosion.
That's good news.Thanks to the dedicated. I talked to you Bob on the Ohio Turnpike,stopped for gas with my Blue SD.After Tri-Power weekend.Good luck.
SDBoB, Yes I do remember you. Thanks, It's nice to meet new pontiac people.
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Brian Baker:
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by FantomPoncho: I would definately go with an aluminum block over the $100 stock block. Why?? Because it's repairable. An explosion would not be nearly as expensive. I suppose if I were to put them in order of priority, it would be: 1. Aluminum Block 2. Stock Block 3. IA2 <HR></BLOCKQUOTE> You're speaking for a blown nitro' application, correct? <HR></BLOCKQUOTE> Yup, sorry for not specifying. Of course, in a street/strip application I would simply reverse #1 and #2. An aluminum block would be great for a street car, but only if money was no object. Of course we could say the same about a lot of things! |
#38
I just wish the aluminum block was made with a higher deck height to get a better rod ratio with longer stroke cranks. Besides, this isn't a normal..... put it in most stock chassis cars anyway.
But something is better then nothing. Would Love to build a ATI Procharged 572 cu.in. Pontiac Street engine. |
#39
What great news!
It's really good to see the Butler family, with their stellar reputation and marketing prowess become involved with AllPontiac. Avoids a lot of duplication of effort and gets it to market much quicker and hopefully with fewer teething problems and maybe even a better price. Congrats!
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
#40
Ok,I already have 2 pontiac alu blocks so I guess I can start this conversation off without too much trouble.
Why do the really high HP natural asperated engines like in Nascar and Prostock run iron blocks.I know the top fuel and funnycars run them for the expansion of running on the ragged edge of hydrolic in the cycs and easy repair.I have read that the iron block will make more HP than a alu block,all things being equal.If that is the case,except for weight,what is the advantage of alu?Tom |
