1968-72 GTO 4SPD CONVERSION PACKAGE FOR SALE
Pictures is a 4spd speed setup gathered from several cars my buddy had over the years. The tranny is a M20 from a 69 Lemans and in very nice shape. I pulled the cover and took a picture of the guts. Still has some yellow paint on the gears. The case has been closed for a while, maybe since new because I had a hard time breaking the seal to take the picture. Check out the pictures for all of the part # and codes. Included with this kit is the transmission, linkages, reverse linkage and back drive & column linkage, good Z bar, swivel set, pushrod, bell housing, floor shifter porch, pedals, brake switch, pushrod (a bit worn), triangular bracket for the clutch boot, a new clutch boot, NOS bell housing boot, pivot frame bracket, new pedal pads and trim pieces, new floor shift boot and trim. Looking for $2000 or b/o for everything. It must be locally picked up. I live near where Performance Years was located... in Lansdale, Pa. Message me if interested. Thanks for looking ... Mike
