Need expert engine advice
My engine was in the car when I bought it almost 20 yrs. ago. I have put 21,000+ miles on it. (total on engine 40,000+ miles). I've always had to add race fuel to the 94 octane and back down timing a couple of degrees to stop it from detonating.
With 93 octane, I need to add a little more race fuel. Since I retired, I drive the car a lot more. It's getting expensive.(1 gal of 116 oct. to <7 gals of 93 oct). I have asked a few local (smart) car guys about installing thicker head gaskets, like cometic .066 crushed.( felpro 8518PT are in it now). I am getting mixed answers, and "quench" was mentioned also. NOT sure what quench. From my documentation book, I have a receipt from "G&R Performance" in Babylon, NY., 502 Rutgers Rd. Dated Oct. 1995. This is what's listed: 1- boiled block and installed cam bearings. 2- Milled the block. (I was told it was "0" decked) 3-bore and hone .030 over 4- polish and radius crank 5- clevite main bearings 6- balance assy. 7- miloden rod bolts 8-seal power rings 9- Lunati cam and lifters (230@50 dur. 460 lift). 10- boil and peen #77 heads. NOT ported, bronze guides, stock SS valves. 11- miloden screw in studs 12- heavy duty seal power springs 13- HS 1.5 roller rockers 14- I put on 65' tripower intake and correct carbs 15- stock exhaust manifolds and 2.5" Pypes "X" pipe system Do you think the Cometic gaskets will help or make things worse??? thanks, Dave Cam card |
