Old 07-06-2004, 07:32 PM
hotroddragn hotroddragn is offline
recently added a holley blue fuel pump as well as new 3/8 ID fuel line from tank to carb. pump seams to overheat and stop pumping completely after only 10 minutes of street driving. can anyone offer some advice on what causes this or if i may have just gotten a bad pump. im also running larger ground and hot wire than required with a relay. any suggestions would be greatly appreciated. thanks
3960 raceweight
13.46 shortshifting
99.6 mph
3.23 axle th350
3k stall
full factory trim
3960 raceweight
13.46 shortshifting
99.6 mph
3.23 axle th350
3k stall
full factory trim
Old 07-06-2004, 07:42 PM
Tom Vaught's Avatar
Boost Engineer
Even though I worked for Holley, years ago,
I have no love for the Holley Blue pump or
its regulator.
Do not put a fram filter on the inlet side of the pump.
Do not mount the pump in the trunk.
Do not use the stock pick-up in the tank to
feed the pump.
Do not mount the pump near any exhaust pipes.
The regulator has a small orifice and will restrict gas flow to the carb on a higher HP engine
Those are the bad things.
Now the good things.
The Trans-Am guys have used the pumps on their race cars for years.
They use two but turn one off unless the first pump fails. Most
times the pump will keep up with the HP of a Trans Am car because
they are on and off the gas all the time.
The pump is not a good pump for drag racing/ street-strip vs other pumps that are out there today.
The over-heating issue needs further investigation.
(see above)
Tom V.
Old 07-06-2004, 07:47 PM
i am also using 2 fuel filters mounted parallel before the pump
3960 raceweight
13.46 shortshifting
99.6 mph
3.23 axle th350
3k stall
full factory trim
Old 07-06-2004, 07:50 PM
Tom Vaught's Avatar
Boost Engineer
Before the fuel pump should only be a screen
type filter.
Tom V.
Old 07-06-2004, 09:01 PM
Ray Cox's Avatar
Ray Cox Ray Cox is offline
Also check your vent make sure it works, but most of all make sure its big enough it cracks me up when I see guys put a giant pump on there fuel cell with a big -10 or -12 line but the tank is vented with a little 1/4 " line that they come with
8.30 @ 165 mph 3,380 LBS
Old 07-06-2004, 09:26 PM
thanks for the advice guys, since the pontiac southern nationals and seeing the help on this site i have discovered that poncho guys are the most sportsman like and best group of racers around, wish the local guys here would pick up on that.
3960 raceweight
13.46 shortshifting
99.6 mph
3.23 axle th350
3k stall
full factory trim
Old 07-07-2004, 05:34 PM
suprchikn suprchikn is offline
Jim, if you are using your original tank with stock pickup and the sock is still attached, debris in the tank (rust etc.) may be clogging the pickup sock.
I burned up my first holley blue within a year from this problem. New tank, no sock, no problem! What narrowed it down quickly for me was that it only happened after I filled the tank. The filling turbulence was enough to put all the crap into suspension which apparently then gravitated directly to the dumb ol' sock. sock sock sock sock sock
sorry about that.
sock
sock
Drive it like you stole it... or it will break!...again!
Old 07-07-2004, 06:50 PM
issach428's Avatar
issach428 issach428 is offline
screen type filter?? what brands? i have always used the little earls filter about 4 inches long with the brass funnel like filter and #8 fittings.
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane.
Old 07-08-2004, 11:27 AM
J.C.you's Avatar
J.C.you J.C.you is offline
thought this thread sounds famliar. Jimmy, try taking the lid off the gas tank and run. if that doesn't fix the problem, i vote for stopped up sock in tank.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 07-08-2004, 11:51 AM
goatseeker's Avatar
goatseeker goatseeker is offline
issach,
Summit "Full-Flow" filter is $28.95 & works well as an in-line screen filter. Comes with AN fittings, flows 390gph, reusable screen filter element, anodized aluminum case.
This is not a good picture - but it's the red thing next to the pump in the pic.
Old 07-08-2004, 04:18 PM
BVR421's Avatar
BVR421 BVR421 is offline
Tom Vaught sed
Whats with that? I just got a big Fram caaister type and dont want to use it if its restrictive.
Now I see the Summit filter looks like a better deal about what I paid for the industrial looking fram. DOH!
Old 07-08-2004, 06:37 PM
goatseeker's Avatar
I had the Fram filter but sent it back because specs show it flows 90gph but my Mallory pump flows 140.
The canister filters work better on the pressure side of the pump than the suction side.
Old 07-08-2004, 07:13 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
Uh oh! I have a Fram filter on the inlet side of my Blue pump. I'm using 1/2" line all the way and 8 AN fittings. I also notice that I get fluctuations in my pressure gauge that I have mounted in the dual feed line at the carb. What could cause this? At all RPM's too. I'm running the regualtor that came with the pump. I'll set it for 6-7 lbs when running at idle and the next thing I know it's at 4 lbs or as high as 9 lbs.
_________________________
Sonny Barger
Old 07-08-2004, 07:19 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
I believe the Fram canister filter flows 90 GPH at like .5 psi. Don't forget to look at what pressure the flow is at when making comparisons. Tom, what is the issue with the Fram unit?
Old 07-08-2004, 07:28 PM
77TA 77TA is offline
my mallory 140 with fram on inlet fills a gallon jug in about 28 seconds through stock 3/8 lines. 1/2 to filter 3/8 from pump to carb. FYI
Old 07-10-2004, 12:23 PM
Taff Taff is offline
I use the Holley blue pump with the Fram cannister filter after it,close to the carb. I rely on the mesh screen in the inlet of the Holley pump to filter the fuel before it gets to the pump, however, as my car is race only, I pour all my fuel through a paper paint filter into the cell and check the pump screen a few times a year. My car runs mid tens with this system,no problem.
