Old 06-04-2023, 08:42 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Default Update on the new engine
Went to test and tune yesterday and made a few more passes. No tuning yet, just trying to work out best settings for a decent launch. Moved the Assassin Bars one hole up from the bottom. Only made two passes but it seemed to work well. 60' is still soft but I know the converter is holding things back. Also a hot and humid day. Anyway, things are headed in the right direction and next time out I hope to try different jetting in the Quickfuel 950 and also try a bit more timing. On the second pass I did something I have never done before and that was a perfect light. Blind luck for sure but still looked good on the board.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
The Following User Says Thank You to prostreet64 For This Useful Post:
Old 06-05-2023, 03:11 AM
Dragncar Dragncar is offline
Hey, those perfect lights are seldom blind luck. They are earned, nice job.
Those are what you want in time trials bracket racing. People hear that over the PA system.
It helps earn you opponents red lights.
Your car has under 10.50 in her when you get those 60 foots down and more tuning.
Old 06-05-2023, 07:55 AM
Thanks for those encouraging words. I do think the potential is there. Will just take some time to sort it out.
Old 06-05-2023, 12:49 PM
beemergary's Avatar
Like you say a little soft on 60FT. I can do better with off idle but hard to make myself do it thinking car will stall or stumble.
Old 06-05-2023, 08:13 PM
ponjohn's Avatar
ponjohn ponjohn is offline
MPH is crazy.
Old 06-12-2023, 09:26 AM
joes455 joes455 is offline
Nice runs prostreet64,what kind of vacation are u pulling at idle with that cam?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 06-12-2023, 09:27 AM
Vac not vacation
Old 06-12-2023, 01:15 PM
Vacuum is around 10 with the idle at 1000-1100. It will idle at lower rpm but I brought it up to smooth things out a bit. I could play around with the air bleeds and probably get a better idle even at lower rpm but it hasn't been a priority at this point.
