Old 06-19-2020, 11:27 AM
beertracker's Avatar
beertracker beertracker is offline
Default Price check on Pontiac 350 & trans?
How much would you pay for this? NOT my facebook ad.
https://www.facebook.com/marketplace...7238138957212/
Old 06-19-2020, 12:10 PM
Sirrotica's Avatar
Since you can't hear it run, or test the transmission, I would offer core prices, and assume both pieces need complete rebuilding.
$100 for the engine, and $50 for the transmission.
I know, "It ran perfectly before we pulled the engine", heard that line way too many times in the past to believe it.
My rule of thumb is core value, unless I can hear it run, or drive it to test the transmission. Even when buying from a junkyard that warranties the engine, or transmission, few places will pay the labor to R&R the parts once in the car, and finding that the part in question is defective. They'll give you another used part, but usually that's as far as the warranty goes.
I made my living for 40 plus years repairing cars, and same as "shipping isn't free", when buying online, labor to R&R defective parts isn't either.
In this case if you found out the part wasn't as good as described, they don't have another unit to give you to make you whole. And good luck getting any portion of your money refunded on a private transaction.
If the seller will allow some disassembly for verification that the used part may be what they claim, then the price can be adjusted. Most people won't allow you to do that though.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-19-2020, 12:52 PM
bdk1976 bdk1976 is offline
At least -$100 (they pay me $100) to remove. I already have a couple of 326s and auto trans cores that I'm too lazy to scrap.
There is a similar ad around here on CL - $500 for a used up 326. It's been up for a while.
Old 06-20-2020, 09:57 AM
Formulabruce's Avatar
The trans is worthless unless you need it. Just scrapped 6 th350 and 4 Th400's (65, 69, 70, 80) all Pontiac
All were working well and I had driven them.
The engine. If original heads, those are 80cc and can be used on a 400. good block too. If there is video of the engine and doesnt smoke or knock, And you want it, could be worth $200-250. Cheap way to get a car running
Old 06-20-2020, 10:29 AM
Frank T Frank T is offline
Wish I would have known about one of those free TH400s
Old 06-20-2020, 11:16 AM
ponyakr's Avatar
ponyakr ponyakr is offline
I've got a '77 350 complete, less carb, & the TH350 that was bolted to it. I assumed the 6x-4 heads should be worth at least $200, probably more. Assume the Q-jet intake should be worth $75-$100, & at least $50 for the TH350 core.
But, I've had absolutely no offer on any of it. As I've said many times, In my area, Pontiac parts are worthless, if you're trying to sell. It's different, if I'm trying to buy, unless it's from a friend.
Good luck !
PS: Just curious. What 1980 model Pontiac came with a TH400 ? Behind what engine ?
"...4 Th400's (65, 69, 70, 80) all Pontiac..."
Old 06-20-2020, 10:52 PM
Good luck !
A 77 EGR intake is .. hard to sell.
A 77 block is not a prize for a 350 as I recall
Heads are worth 200 , yup
Right now scrap #2 any metal is low.
Pure AL is worth a bunch more.
I should have been more clear on the '80 TH400
Came from a Caddy with an Olds engine ( I think)
and had the BOP-C bellhousing, where the others were just BOP.
Pretty much the first year and last year TH400 in that load.
None were PQ
Old 06-24-2020, 10:26 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
I've got a running non-smoking 1970 Pontiac 350 with 350th transmission for sale.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
