Old 01-16-2004, 05:26 PM
1157 motor head's Avatar
1157 motor head 1157 motor head is offline
DOES ANY ONE KNOW IF A 70 GTO HAS A TOP PLATE THAT BOLTS ON OVER THE CORE SUPPORT?? OR WAS THIS ONLY FOUND ON A LeMANS ??? I THINK THERE SOULD BE A FILLER BETWEEN THE CORE SUPPORT AND THE NOSE..
JIM
JIM
Old 01-16-2004, 06:34 PM
darren darren is offline
Yes there is a filler panel that bolts to the rad support you can buy a repo
Old 01-18-2004, 01:31 AM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
Just to clarify, the 70 GTO top plate is just a black plastic cover, not a steel tray like on the lemans. There are fiberglass and plastic repops.
GR-RRR!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 01-18-2004, 08:31 AM
ScottN ScottN is offline
I bought a plastic one from PY and the fit was great.
Trying to find an original one in good usable condition will be extremely tough.
Old 01-20-2004, 02:42 PM
slowgto slowgto is offline
Scott Nimons, was the filler you bought like your original? When I looked for one everybody was selling the same one, which had a textured pattern, and it didn't look like my original.
Old 01-20-2004, 03:41 PM
Gordon Church Gordon Church is offline
Does any one have a GTO that came from the factory without the filler panel? Mine and another very original 70 never had one. They are both non air cars and have close build dates 4/70
Old 01-20-2004, 06:05 PM
428GTO70's Avatar
I believe the plastic repo's to be very close to original. I have heard the top is correct looking but the underside is incorrectly grained, but you would never see that once installed. Not only that but the plastic ones are cheaper than the incorrect fiberglass ones. This is just what I have read though.
GR-RRR!
Old 01-20-2004, 06:26 PM
oldgoat70 oldgoat70 is offline
My 70 doesn't have one either. it was built 1/70.
Old 01-20-2004, 07:51 PM
SlowGTO,
What 428 said.
I think it looks good. It really polishes off the top of the radiator support, hiding all the bolts and closing the gap between the support and the nose.
I can get a pic if you'd like.
