Old 04-09-2024, 11:48 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Factoring no mechanical issues with the motor, Track time is a better indicator of power since he already has a reference point if the car is basically the same.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
  #42
Old 04-09-2024, 12:06 PM
True!
  #43
Old 04-10-2024, 04:00 AM
gman005's Avatar
gman005 gman005 is offline
Well the leak down test was anywhere from 4 to 13%. Nothing going on internally. I will try and do a compression test today.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
  #44
Old 04-10-2024, 06:53 AM
johnta1 johnta1 is online now
If the only changes were cam, rods and heads, I'd say the combo needed tuned to those new changes? Intake specs to work with the heads, carb change to work with the new specs, cam wrong for head specs etc.?
What was the afr, bsfc, rpm range etc?
  #45
Old 04-10-2024, 09:16 AM
PAUL K's Avatar
PAUL K PAUL K is offline
I believe the heads were direct replacements for the original KRE heads that cracked.
I'd be looking to see if the porting program was changed to prevent the cracking issue. This problem was in a critical area of the port. Could easily knock down the power numbers considerably.
Go fast, see Elvis!
  #46
Old 04-10-2024, 10:37 AM
Thanks, I thought with the heads they were ported for more flow than previously. (why he changed the cam also)
  #47
Old 04-10-2024, 12:57 PM
bluegoat65 bluegoat65 is offline
Good call by Paul. That would suck if thats the case. The High Ports gotta be paper thin at 430. Hate to say, but maybe move your program into the "Super Wedge head" territory. Your easily at that level.
  #48
Old 04-10-2024, 01:49 PM
Stan Weiss's Avatar
JMO It is the new cam.
Stan
Pontiac Pump Gas List
  #49
Old 04-10-2024, 02:22 PM
gman005's Avatar
I talked to Jeff yesterday he said that the new port program shouldn't have hurt it. We all know how that goes.
71 Lemans Sport.
72 Lemans Sport.
  #50
Old 04-10-2024, 02:39 PM
gman005's Avatar
I changed the cam hoping to pick up a little.
71 Lemans Sport.
72 Lemans Sport.
  #51
Old 04-19-2024, 12:48 PM
grandville455's Avatar
Any new updates?
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
  #52
Old 04-19-2024, 04:34 PM
gman005's Avatar
Hey Darby. Im going to the put motor in and run it. We will see what happens.
71 Lemans Sport.
72 Lemans Sport.
The Following 2 Users Say Thank You to gman005 For This Useful Post:
