Old 01-07-2017, 06:07 PM
stroker461's Avatar
stroker461 stroker461 is offline
Default motor plate/ crank trigger
What up guys, I ordered an All Pontiac front motor plate for my junky ole firebird friday so i havent got it yet, just curious how ya guys that are using crank trigger are mounting the bracket and sensor? My theory is that frank at All Pontiac said the plate is 1/4" thick and the sensor bracket is bolted where the front plate bolts up, so this means it will push the sensor out a 1/4", so me and my engine builder discussed this situation and came to the conclusion that if we mill a 1/4" off the sensor bracket then everything will stay exactly where it is at right now, we do not have to move the sensor around due to timing adjustments will be made through the power grid system..... thanks in advance for all replies and photos or suggestions......
Old 01-07-2017, 06:33 PM
Robert C.'s Avatar
Robert C. Robert C. is offline
See the pictures on our Web site. Dont Panic. It will be easy mount.
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 6.027@231.64
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
Old 01-07-2017, 06:34 PM
Robert C.'s Avatar
See the pictures on our Web site. Don't Panic. It will be easy mount.
Bob C.
Boss Bird Funny Car
Old 01-08-2017, 01:14 AM
bluegoat65 bluegoat65 is offline
I slotted the plate and removed the 1/4"thickness from the bracket. worked well no probs.
Old 01-08-2017, 10:21 PM
Probird's Avatar
Probird Probird is offline
X2...
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
The Following User Says Thank You to Probird For This Useful Post:
