Clutch and pressure plate recommendation?
Just finished the rebuild of a stock 400 to a built 461 stroker. Figure about 425 hp and 500 lbf-ft. When the trans was installed, a stock replacement Sachs clutch and pressure plate were installed. I don’t have confidence in the longevity of this clutch even though it has very few miles on it. The car is just going to be used as a fun street car and I don’t have plans to take it to the track. So, does anyone have a recommendation of a budget friendly, won’t wear out my left leg, street clutch/ pressure plate combo? Not looking to upgrade to hydraulic at this time.
1970 GTO 400 Atoll Blue, PS, PDB, A/C Was M20 4 speed, now has Keisler RS600 5 speed. |
Stay with an organic clutch.. ACT, Mcleod, CenterForce., Spec, Ram, Hayes. Lots of manufactures out there. Lots of post on P/Y also. For safety you could also look into a SFI approved clutch. Billet steel flywheel and a SFI approved bell housing. Expensive yes but so are your legs if anything happens. I like the Quicktime bell housings.
Have had great luck with McLeod,have them in all 3 of my cars.Tom
The Following 3 Users Say Thank You to tom s For This Useful Post: | ||
https://www.summitracing.com/parts/mcl-75221
Looks reasonable.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
I have probably 100hp less than you in my setup but I run a LUK. Easy on the wallet and my left leg.
1977 Trans Am 400/4speed (swap) Brian |
I also run a LUK. Very happy with that companies' Clutch and Pressure Plates.
Tom V.
