Old 04-01-2014, 08:40 PM
JIMMYM JIMMYM is offline
Default 1965 gto post coupe window mouldings
Any tips on putting window mouldings on my back on my post coupe window frames? also best way to install my drip rails. i just got the headliner installed and am taking it monday to have all new glass installed. any reason that the side window mouldings cant be installed after the glass? any help will be greatly appreciated.
Old 04-01-2014, 09:12 PM
rsavage's Avatar
rsavage rsavage is offline
Not sure what window mouldings you are referring to - reveal moulding? The drip rail mouldings can be installed by lipping them over the top edge and snapping them down over the bottom edge. Corner piece goes on last of course.
1961 Corvette 4spd.
1969 Chevy K5 Blazer - currently restoring
Old 04-01-2014, 10:42 PM
james66GTO james66GTO is offline
Default Post Window trim
Does this youtube video help you?
http://www.youtube.com/watch?v=UmFgSlpffiI
Old 04-01-2014, 10:49 PM
hhs66's Avatar
hhs66 hhs66 is offline
Jimmy, matter of fact, I was working on that tonight. Here's the way I see it and I don't know if it's the correct order but this is where I'm at. I'd wait until all the glass is installed. That will leave more room for the installer without trying to work around your newly polished trim. The trim can be installed last. I installed the front rear quarter glass run first. Easy. A short piece of channel that clips into the body. Next, I installed the rear glass run channel assy. that runs in the body channel above and down the rear of the glass. I had this reproed by Restoration Specialties out of Pa. I had to tweak it a bit because the pins did not line up just right but a bit of grinding made it fit. It appears that when you get to installing the trim, you will need 3 clips on the angled piece and two clips on the straight piece on the front of the rear quarter window. It looks as if the clips should be installed in the trim first. They will have to be spaced to line up with the spaces in the pinch weld you will find around the quarter window. Three on the angled piece and two on the vertical straight. As far as the door, if you lay it out, you can see which piece overlaps the rest of the pieces. If you need some photos, PM me and I'll hook you up. Skip
They say money can't buy happiness but it CAN buy ammo and that's kind of the same thing.
Old 07-23-2024, 08:22 PM
64rescuration 64rescuration is offline
Default Replacing clips
I bought my 64 post and it was already taken apart. I am missing all but 3 of the clips. Any idea where to find replacements? Everything I’m finding seems too small and I can’t find an exact match at all. Any suggestions on what size clip will work?
Old 07-23-2024, 08:43 PM
Post a free ‘parts wanted’ ad for what you’re looking for in the appropriate classified forum.
Someone likely has what you need sitting around from a car they’ve parted out.
Old 08-30-2024, 08:07 AM
MDSHARK81 MDSHARK81 is offline
Does anyone have a recommendation for a metal refinishing shop to restore the original door window trim on my 65 GTO Post coupe. I believe they are anodized aluminum.
Old 08-30-2024, 11:31 AM
Rich-Tripower's Avatar
Dennis Barnett with Classic Moulding Restoration is one of the best.
CLASSIC MOULDING RESTORATION
1099 N. GLENDALE LANE
GREENFIELD, IN. 46140
(317)919-8434
Old 09-02-2024, 09:06 AM
Great…. Thanks
Old 09-02-2024, 10:24 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
(317)919-8434
Dennis did a lot of polishing for me years ago. I did not know he was still doing it.
He went by the name "Stainlessman" on this site.
Old 10-30-2024, 10:35 PM
Brad_bb Brad_bb is offline
I believe these moldings are Aluminum. So be gentle. They'll probably go on easier than coming off. I used various blocks of hardwood to carefully release the moldings from the door frame. Mine when back on a lot easier than they came off. I think I just used my hands if I remember right. It's been half a dozen years since I put them back on. I'd put them on before you install the side glass. I have not put my drip moldings on yet, nor have I installed the windshields. Edit: See the video link in a post above of a video I made about this and forgot I made it until I clicked that link, duh.....
If someone else can design it, I can sure figure out how to fix it.
Old 10-30-2024, 10:46 PM
Haha, I totally forgot that I made that video! Glad somebody kept the link! Brad
Old 10-31-2024, 07:45 AM
tempest1964's Avatar
Nice video Brad!
Thread Tools
Display Modes
