Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
2003 Chevy gauges not working
Bought a 2003 Chevy 2500hd/8.1 last week and all was well. This morning i head to the store and all is well, get back in the truck and now i have NO gauges that work.The digital odometer still works but nothing else. I looked in the owners manual and all i found under fuses was one that said cluster/hazard/blinkers. Hazard and blinkers work fine. Any ideas?
Note: It was a ground issue. All fixed now. Thanks
If im not mistaken there is a tsb out for this issue. My best guess is the cluster has failed its pretty common, Id get a wiring diagram and check for power and ground at the cluster itself but I would lay money down that the Cluster itself has crapped out on you.
I bet RS72LEMANS is correct. The gears strip on the servo motors that drive the needles....if it has not failed, it will. GM offered free replacement on certain models up to 7 years/70000 miles. I had mine done last summer.
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
I fixed it. It would up being a ground wire from the firewall to the hood?????? Anyways that wire was damaged and when i shook it, the gauges went back to work.
UM? firewall-hood? like for a hood light?
Its wierd. Its on the drivers side and the hood light is on the passenger side.
