Old 11-03-2021, 01:47 PM
GoGoat GoGoat is offline
Default Installing trailing arm bushings
Whats an easy way to install the upper trailing arm bushing on a stock 66 rearend? Pound them in or use a large c-clamp? Also should I grease them before installing? Thanks
Old 11-03-2021, 02:03 PM
ErikW's Avatar
ErikW ErikW is offline
https://www.ridetech.com/product/bus...pper-bushings/
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
The Following User Says Thank You to ErikW For This Useful Post:
Old 11-03-2021, 02:08 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Whatever you do, Do not pound them in. You can snap off the ear on the rearend if you do.
The Following User Says Thank You to Bruce Meyer For This Useful Post:
Old 11-03-2021, 02:29 PM
scott70's Avatar
scott70 scott70 is offline
Once I drilled out the rubber mostly and then took a cold chisel and folded it in on it self. Then lightly hammered out the rest.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 11-03-2021, 02:39 PM
indymanjoe's Avatar
Same here as above.
Old 11-04-2021, 01:17 AM
lust4speed's Avatar
lust4speed lust4speed is online now
Cheat and do some sanding on the inside of the ears before trying to get the bushings in place. Putting a slight bevel on the corner edge of the ear on the side the bushing goes in helps, as does grease on the outside of the bushing. I never had luck trying to pull/press them in place and usually ballooned the bushing shell. Hammering is nerve wracking but it worked better for me.
Mick Batson
Old 11-05-2021, 12:19 PM
Schurkey Schurkey is offline
Rubber, or Polyurethane?
There's a HUGE difference in the way they're installed, with the least-risky, least-labor-intensive ones being Poly.
Warm up the steel sleeve with a propane torch. The rubber largely slides out on it's own, but you can encourage it with a big punch and a hammer.
Clean the outer shell, sand/emery cloth as needed to make it pristine inside. Grease the shell and the bushing with the "special" grease they supply with the bushing set. Grease the inner sleeve and the ID of the bushing, too. Slide everything together--finger pressure should suffice.
Point being, you don't press the shells out of the part, you re-use the original outer shells. No press, no special tooling, no need to have the vehicle at normal ride-height before torquing the bolts on reassembly.
Not having the vehicle at normal ride-height when torquing the bolts has ruined plenty of rubber bushings. The springs get the blame--it "took a week for the springs to settle". No, it took a week for the rubber to tear free of the metal pieces (inner sleeve, usually, but sometimes the outer bushing shell) it was bonded to.
Downside to Poly bushings on the rear? The Poly bushing inserts tend to be firmer than the rubber used in OEM bushings. Rubber flexes more, reduces binding of the suspension. Keep in mind, GM deliberately designed the rear arms to be flexible in torsion, strong in compression and tension. Then folks remove those arms in favor of "stronger" aftermarket arms that don't flex in torsion; and wonder why the ride is rougher/noisier/harsher.
Old 11-06-2021, 01:18 PM
Default Got them in
I followed your advice. Cleaned all surfaces with sandpaper, cleaned, greased and pulled them in with pull bolt and verity of spacers-bushings. Thanks for all the help. Went very easy.
