Old 06-24-2024, 08:25 PM
indymanjoe's Avatar
Default Header fits! As in I知 having a fit
Doug痴 headers on Edelbrock round ports. Pass side I got no issues. Drivers side.. here痴 my question should I notch the frame where the a arm attaches? Or dent the 1200.00 header..it also looks like I have to shave a little off the motor mount as well as it looks like it痴 paper thin to touching the #1 tube
ID:	635860   Click image for larger version
Old 06-24-2024, 08:31 PM
indymanjoe's Avatar
Generalz this is the stuff thats killing me LOL i went your flex line route for the pass side as the trans cooler lines wouldnt fit. And i thought that side was gonna be the pita. My dougs D-ports with iron heads fit perfectly. now from the searches im discovering the e-heads are wider....
Old 06-25-2024, 01:33 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default Welding
You good at welding?
Cut the radius off the suspension mount on that side and weld in a flat plate to connect to two sides.
Don't trust yourself welding, well you know the other option.
It is a suspension component. better do it right.
Least if you have to dent the header you won't see it from up top.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
The Following User Says Thank You to skunkwerks For This Useful Post:
Old 06-25-2024, 03:12 PM
indymanjoe's Avatar
Yea the header is getting pulled off heated up and a couple whacks with a ball peen hammer and im calling it good. I can stick metal together but i don't trust my welding skills. thanks
Old 06-25-2024, 03:18 PM
indymanjoe's Avatar
On a side note a buddy sent me this. How cool lol
Old 06-25-2024, 06:42 PM
indymanjoe's Avatar
So tbfh to the rescue. I used a product I use at work for refrigeration to keep heat off things you don稚 wanna incinerate called Thermo trap. It does a great job at absorbing heat so I didn稚 have to destroy the header. Tubbys got them nice and hot. Bunch of smacks with the hammers. Put it back in. Took it back out. Put it back in took it back out. Looks like this is gonna work just fine
ID:	635912   Click image for larger version
ID:	635913   Click image for larger version
Old 06-25-2024, 06:54 PM
indymanjoe's Avatar
With the motor lifting on this side I think I値l be ok. Pics didn稚 turn out but it looks like a 1/2 inch from frame.
ID:	635917   Click image for larger version
Old 06-26-2024, 01:11 PM
pggto's Avatar
pggto pggto is offline
I had the same problem with mine. Doug's with O-port E-heads. I called there tech support, they told me to "ding" the tube. I spent $1000 on coated headers and you want me to take them out of the box and take a hammer to them. I sent them back. I ended up buying the OBX (?) Doug's knockoffs that were stainless and took a hammer to them. Those headers were a fraction of the price, about $300 if I remember right. Not sure they even make them anymore.
The Following User Says Thank You to pggto For This Useful Post:
Old 06-26-2024, 02:47 PM
indymanjoe's Avatar
yea I'm not thrilled about it but with all the delays I've had i just want this done.
Old 06-26-2024, 03:45 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
I woulda cut some off of that bracket. Wouldn't hurt a thing as long as it was blended well. That ding in the tube won't hurt anything either though.
Thread Tools
Display Modes
