Old 06-22-2024, 08:18 AM
steve25 steve25 is offline
The change and resultant improvement in post #11 is why for any car ( even a duel purpose vehicle) intake system averaged air speeds have be thought about carefully and that FPS number guided by what the power band will need to be.
Itís been shown that the highest peak HP takes place with an intake system air speed of 350 FPS for a short moment in time..
Consider the fact here that with the best NA conditions ( 14.7 psi ) that at 5000 rpm it takes .006 seconds to fill a cylinder to even just 100% VE makes it clear that moving air fast as can be tolerated is important!
Many top Indy motor designers for a while now consider that a intake system peak air speed of 450 to 470 FPS working best for there needs.
Cylinder heads need to be sold sold not only with stated air flow numbers, but with intake port air speeds with different CID motors under them.
So many folks with money invested in aftermarket heads they have that can flow over 320 cfm are far from really using the power potential there heads have.
Old 06-22-2024, 09:40 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Craig any difference using the Northwind?
Steve 25 I think standardizing velocity is going to be difficult. Many good shops don't have the probes -or time- to do that. Then there is the different areas of the port that have different velocities-where is the "standard spot"?
Skip Fix
Old 06-22-2024, 10:09 AM
You can get a really good picture of what’s going on even without having a velocity probe, this takes a good amount of math and also having a lot of previous experience / time in probing ports.
Like you know finding the velocity thru a given port area is easy once you have a few numbers in hand, but it’s what happens when that air mass goes around any kind of bend or pinch point where having the in hand probe experience pays off.
Old 06-22-2024, 10:43 AM
i82much's Avatar
i82much i82much is offline
has anybody tried 3d printing a pontiac intake?
Stan Weiss's Avatar
In the cylinder head calculations which I have programed with David Vizard. The User has the option to enter the max air speed as a Mach #. If not, it is calculated. When calculated, what is normal (if everything is sized correctly) is somewhere around .55 Mach or about 620 fps.
Stan
Pontiac Pump Gas List
Old 06-22-2024, 02:53 PM
Tim Corcoran's Avatar
Stan
For a 4.18 bore and 4.25 stroke with 333 CFM Edlebrocks, 13.1 compression, a solid roller with 264/268 dur. @ .050 and .650 lift. At what RPM would it need to turn to justify a 1050 on top of a Victor? Is there a better manifold for this application?
Tim Corcoran
Old 06-22-2024, 03:25 PM
ta man ta man is offline
Originally Posted by 65 Lamnas View Post
I'm not sure if you directed your statement to me or not, but if you're talking to me, we're not testing any Torker intakes, and the 3 we ARE testing are (or will be) ported. There will be no out-of-the-box stock intakes tested. Pretty much everything Derek does is verified and validated by testing whether it's a flow bench or dyno. It's not his first rodeo, and it's also why I chose him for the work.
Derek ported a Torker 2 for me a few years ago and it was worth a solid .1 to .15 and 1 to 1.5 mph in the quarter mile. I'm currently at 127mph plus in the quarter mile with the same intake but it has been touched again by Dave Bisschop to match and open up the runners to my heads. This year I have a Northwind to test with..
Old 06-22-2024, 04:19 PM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
Iíve wondered this for awhile . A plastic copy of a 68-72 iron would be awesome .
When I wore a younger man's clothes
Old 06-22-2024, 04:21 PM
Stan Weiss's Avatar
Originally Posted by Tim Corcoran View Post
Stan
I don't have an exact answer for you. At SAE 607 Dyno Correction 1.00. 1050 SCFM is about 4800 lbs / hr. How much the engine wants is not only based on RPM but also VE.
Engine_Size_=_466.5748
Barometric_Pressure_=_29.9200__-__Temperature_=_60.00
Air_/_Fuel_Ratio_=_13.00000
_6100_-_RPM
__________________________________________________ _______\|/
BSFC_________________________________0.4100___0.43 00___0.4500___0.4700___0.4900
___VE%_____Air______Air______Fuel_____BSFC_____BSF C_____BSFC_____BSFC_____BSFC
__________kgs/s____lbs/hr___lbs/hr_____HP_______HP_______HP_______HP_______HP
_1.2742_0.60559__4806.375__369.721___901.76___859. 82___821.60___786.64___754.53
_6300_-_RPM
_1.2342_0.60581__4808.135__369.857___902.09___860. 13___821.90___786.93___754.81
_6500_-_RPM
_1.1942_0.60479__4800.002__369.231___900.56___858. 68___820.51___785.60___753.53
_6700_-_RPM
_1.1542_0.60252__4781.974__367.844___897.18___855. 45___817.43___782.65___750.70
_1.1742_0.61296__4864.834__374.218___912.73___870. 27___831.60___796.21___763.71
_6900_-_RPM
_1.1142_0.59900__4754.053__365.696___891.94___850. 46___812.66___778.08___746.32
_1.1342_0.60975__4839.387__372.261___907.95___865. 72___827.25___792.04___759.72
_7100_-_RPM
_1.0942_0.60530__4804.045__369.542___901.32___859. 40___821.20___786.26___754.17
Stan
Old 06-22-2024, 04:22 PM
tom s tom s is offline
3D printing in metal is very expensive,takes a big cabnet.If you have a dry intake there are plenty plastics to use but that eliminates carbs..Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 06-22-2024, 04:31 PM
i82much's Avatar
what about carbon fiber? could you dip the manifold in a gas-proof resin?
DaleO's Avatar
DaleO DaleO is offline
I'm curious why a 67 intake is not included?
Old 06-22-2024, 04:48 PM
67 has the 1 year only heat passage in front of the primaries .
Old 06-23-2024, 12:21 PM
Dragncar Dragncar is online now
Stan
I believe mine is 625 fps. So far the engine seems to run great. Just put a Magnaflow 300 pump on he with a test and tune this Friday. Big Bucks bracket race Saturday regular bracket race Sunday.
Been 4-5 years since she has been out to the track.
Going to go give those guys some.
Old 06-23-2024, 12:40 PM
Cliff R's Avatar
Cliff R Cliff R is offline
A factory iron intake unless it's from a Super Duty 455 or had material added to it will be hard to open up and have enough sealing surface left for 325cfm heads (I'm assuming they are NOT the stock gasket size anymore).
For single plane intakes, especially with spread bore carburetors at least a 1" spacer is going be needed to get best numbers. Single plane intakes at the dyno sessions I've done did NOT fair well with Q-jets or TQ's. I'm guessing the huge secondary throttle plates sticking deep into the plenum area cause turbulence and distribution issues.
The first time I ran into this was using a Tomahawk intake on a very similiar engine topped with a late 1980's 850cfm Q-jet. The numbers were just WAY down on it. After a dozen or so pulls messing with timing and fuel curves we installed a Victor/Dominator instead and picked up nearly 100hp., Yes, that's NOT a typo.
So we put the Tomahawk back in place with a very well blended 1" custom spacer for it and tried the Q-jet again. It made within 10hp/12ft lbs torque of the VIctory/Dominator. So for that particular combination the Tomahawk intake was off nearly 90hp without the spacer under the Q-jet.
Jump ahead a couple of years and I did a similar test during a private track rental and swapped on a Tomahawk intake and Q-jet without a spacer on it and low and behold it KILLED ET and MPH. Then I put a 1" spacer on it, Q-jet back on it picked WAY up at every point on the run. Then I went one step further and installed my Holley 850 DP carb with the 1" spacer and ran the highest MPH of the day clearly showing that those intakes LOVE spacers on them AND throttle plates that are all the same size and depth.
So for the topic at hand here you may want to include spacers as part of the single plane intake testing and maybe even borrow an HP 950 or Holley 850DP carb to throw into the mix.........FWIW......
The Following User Says Thank You to Cliff R For This Useful Post:
Old 06-23-2024, 01:17 PM
Stan
Well, I am going to find out at the track a similar question. 4.155 bore 4.25 stroke 359cfm High ports, 11.5 compression, a solid roller 265/274dur @ .050 and .731 lift.
Starting out with a HP 850 and have a modified 1050 to try.
Intake is a Victor 4500 with plenum work.
Only intake I think would be better is a highly modified Warrior like Paul has.
Good luck getting one.
Old 06-23-2024, 07:34 PM
Formulajones's Avatar
A dyno will tell ya what you want to know, or if you have time to track test.
Dad found interesting results that don't really follow any math formula
His 571, 4.750 stroke and 4.350 bore, over 700 lift cam and heads that flowed almost 360 cfm. Has a victor on it that bischoff ported. Bischoff did the whole engine actually.
On his dyno his 1250 dominator dyno carb only make 6 more peak HP than the little 950hp 4150 that I prepared. Actually the small carb made more average HP and torque over the whole curve. That made the smaller carb the obvious choice.
You'll just have to try it and see. Every engine seems to respond a little different.
https://youtu.be/XqEydRRRwqE
  #38
Old 06-23-2024, 10:14 PM
Edelbrock tried many non metal materials for 3D wet intakes and none would last for any amount of time and failures were catastrophic.Tom
The Following 3 Users Say Thank You to tom s For This Useful Post:
  #39
Old 06-24-2024, 05:17 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
Gonna have this spacer on hand for the HSD.
Name:	Image 6-23-24 at 4.02 PM.jpg
  #40
Old 06-25-2024, 09:42 AM
Cliff R's Avatar
Haven't seen or tried one of those. I did test spacers, four hole, fully open, fully divided and a "modified" 3 hole or "semi-open".
The four hole and fully open were complete TURDS on dual plane intakes. The fully divided did fine, and the semi-open (much like the one Jim Hand shows in his book ran the highest MPH for all testing at the track. It did NOT however run quicker in ET. Quickest ET was with no spacer at all on my "modified" iron intake. I will add that it may have been the Shaker bases used to clear the hood. Raising the carb up 1" requires differnt Shaker parts, which I used for the testing. Not being EXACTLY the same parts may have flawed the testing a bit. Even so I found it remarkable that the factory intake with only one 1/4" thick open gasket on it outran everything else that was tested.
In any case when I tested taller intakes and spacers, and tried to use a shorter filter, or any type of "drop base" air cleaner assembly that moved the lid closer to the carb I lost power (ET/MPH). This required not using a lid at all, and making a custom air filter for the opening of the Shaker assembly. This makes me wonder how many folks go to taller RPM intakes, or intakes that require a drop base air cleaner and kill off more power and vehicle performance than they ever hoped to gain?
I also tested the K & N Xtreme lid, and it was a complete FAILURE. For some reason it induced a "stumble/hesitation/bog" going to full throttle on the starting line that would NOT tune out. Removed it or replaced it with a lid and the problem went away. Never did figure that one out but for sure my set-up absolutely HATED that part......FWIW.....
Thread Tools
Display Modes
