T400 Pontiac the same BP as Chevy?
Is the Chevy bolt pattern the same as pontiac, referring to the t350 and t400?
Or is it just Buick, Olds, and Pontiac that same the same bolt pattern?
You picked a fine time to leave me loose wheel ........ |
bolt pattern
nooooooooooooo
no but theres an adapter plate u can use
BOP had the same, chevy is different.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
There are dual pattern TH-350's out there,have one in the garage right now...
TH-400's,yeah either BOP/Cad pattern or chevy pattern. |
Thanks.
