Old 12-30-2012, 05:37 PM
thebrat1967 thebrat1967 is offline
Send a message via Yahoo to thebrat1967
Default power steering problems
If it's not one thing it's another! I have had my cars front end jacked up for quite some time and when I started it the wheels turned to the left and would not go back due to the pressure. I noticied that the reservoir was also over flowing. My 1st thought was the pump is bad so I took it off and cleaned the check valve. While on the bench I filled the reservoir and filled a can with fluid, put one hose in the fluid and the other out, all it did was drain the reservior
took a drill and turned the pully. This is where I am lost as shouldn't the pump, pump fluid out of the can through the pump and back into the can? or am I completly wrong on this approach?
Thanks, Sparky
Old 12-31-2012, 12:00 AM
Grand73Am Grand73Am is offline
The times I've seen that happen is when the hoses are reversed on the power steering box. Any possibility of that?
Steve F.
Old 12-31-2012, 12:33 AM
010752's Avatar
010752 010752 is offline
The return hose is not a suction hose. The tank or can is vented and the pump suction ports are low inside the tank.
If you want to run it with a drill off the car, the just stick the pressure hose into the fill opening, make sure the tank is to fill line and drill away.
Old 12-31-2012, 10:41 AM
no the lines are right, I have been able to drive the car in the past and had no problems. started happening when it was in the air for some time
Old 01-02-2013, 12:44 PM
428RA4's Avatar
428RA4 428RA4 is offline
Confirm that the lines are a not collapsed or blocked.
Old 01-02-2013, 11:26 PM
lines are not blocked
Old 01-02-2013, 11:30 PM
Default stand test
i can get the pump to pump on the stand with a drill. could the problem be the
power steering gear? is there a check valve possibly stuch in it?
Old 01-04-2013, 12:38 AM
A.W.Dille A.W.Dille is offline
Possibility that a valve is stuck in the steering box holding pressure to where it's trying to backfeed to the pump and not letting the fluid on past through the box. I have had a similiar problem years ago in my GTO before I converted it to manual steering.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
