Old 06-01-2023, 01:53 AM
mike76 mike76 is offline
Default rag joint replacement on 76 trans am question
Looks like I will need to replace . I know to remove the clamp bolt to the steering box input shaft but how do I make room to remove the rag. Do I just collapse the intermediate shaft? Or do I have to completely remove it. I don't want to break something. Thanks for any help, Mike
Old 06-01-2023, 09:31 AM
glenn911's Avatar
glenn911 glenn911 is offline
Collapse shaft if not rusted together.
Old 06-01-2023, 10:25 PM
Brentco's Avatar
Brentco Brentco is offline
X2. You just remove the bolts on the rag joint and the shaft will move enough to put a new rubber coupler in. Just make note of the bolt orientation and placement of all the hardware first because it has a specific assembly.
1976 Trans Am Buccaneer Red
468ci, 10.5:1 CR, 87 CC RPM CNC e-heads, HR 282/288, 230/236, 561/.573 lift, Johnson Lifters & HS 1.65 Rockers
Old 06-02-2023, 06:02 PM
stevep's Avatar
stevep stevep is offline
On big Pontiacs, I remove the 3 bolts from the box and move it forward a bit
Old 06-02-2023, 06:40 PM
Brentco's Avatar
<— That's right. You do usually have to remove the bolts from the steering gear and swing it away from the frame.
Also if your MY had the "energy absorbing" steering column, remember that you have to be careful with the column shaft so you don't collapse it.
