Old 12-07-2022, 11:02 PM
64speed's Avatar
64speed 64speed is online now
Default Keyless entry
Anybody have it or install it? What kit did you use?
Old 12-08-2022, 07:02 AM
I've worked on those systems before.
Don't remember the brand but customer brought in a 40 ford with it and it wasn't working right.
After 2 days of fiddling and fixing a bad wire job the controller had to be replaced. I quickly became "not a fan"
Lol
Just more gadgets and gizmos that fail and cost money.
https://youtu.be/XqEydRRRwqE
Old 12-08-2022, 07:22 AM
67drake's Avatar
67drake 67drake is online now
Lol
I agree. I’ve never installed one myself, but my first thought was “Another gizmo that will go out on you.” Plus most aftermarket things these days are pretty much junk IMO.
13.95 @ 102.1 on street tires @ 4055lbs.
Old 12-08-2022, 08:38 AM
The Champ's Avatar
When you shave the door handles off your wife's '72 Camaro, you have no choice but to go with keyless (and handleless) entry.
We put this in the car about 20 years ago and I don't remember where I got the kit. It's worked well after I switched out the original door poppers with bigger ones (the Camaro doors are very heavy). Since then, they've been very reliable.
I did not do the install. I don't like messing with wiring and am willing to pay someone to do stuff that I'm not good at.
I'm sure that there are good kits to do the simple task of just unlocking the doors vs actually opening the doors via a key fob.
Name:	Camaro DSC_2064 checkers.jpg
Old 12-08-2022, 09:19 AM
The 95-97 Towncar keyless works well. Controller is in the driver door. Maybe that system lifts out with its own harness.
Old 12-08-2022, 10:46 AM
Stuart's Avatar
Stuart Stuart is offline
There are any number of them, I suspect they're all about the same as far as performance is concerned. There are some that just control central locking, plus there are some that include remote starting, and some that include an alarm system, so you have to pick which type you want. If it's for your Tempest you'll need to get a kit that includes actuators. I see on Amazon you can get a kit for under $30 so it will be a cheap experiment. https://www.amazon.com/s?k=central+locking+system+kit
Old 12-08-2022, 11:04 AM
ta man ta man is offline
I have a Electric Life kit in my car works well. I also have the trunk on a remote.
The Following User Says Thank You to ta man For This Useful Post:
Old 12-08-2022, 11:08 AM
Ha, that's what the 40 Ford was, shaved handles, so taking it out and filing it in the round can wasn't an option. He brought it over complaining he couldn't get in the car Luckily it was a 4 door so he had 3 other chances. The passenger rear was the only door that worked so he had to climb through the car.
I mainly see this stuff on the pre-war vehicles. Those street rod guys like this stuff for some reason.
Old 12-08-2022, 11:30 AM
The Champ's Avatar
FJ
Once I upgraded the door poppers, the Camaro's doors have operated just fine for over 15 years. We are very happy with them.
I would think that a simple keyless entry system, that has only a fraction of the complexity of what's required for shaved door handles, would be as reliable as what my factory keyless entry systems have been for the last 20 years. Assuming a proper installation, of course.
Old 12-08-2022, 11:54 AM
FJ
Yeah I didn't build this particular car, I was just the one stuck fixing all the issues Bleh, My least favorite thing to do is go back through a car someone else built.
Anyway, it's still working fine, been a few years now. I'm actually restoring one of his other cars as we speak.
Old 12-08-2022, 04:18 PM
64speed's Avatar
I am just fishing for ideas. This car truly is my regular (not daily) driver. I had 3800 miles on that engine already when I blew it up so I suspect I will drive it a good bit more when its a little tamer and some things are just convenient
Formulabruce's Avatar
I use a MES system , and have used Electric life. NO keys touch my paint. Trunk is on remote as well as doors. At cruise in or car show I dont worry about my wife or others attempting to get into the trunk. Can be also programed to lock the doors when in gear, or hooked to a security system. Under 100 bucks, well worth it.... BUT. Will drain battery over a long winter sitting.
Old 12-08-2022, 09:05 PM
chuckies76ta's Avatar
Nice color. May I ask, What brand rims are those? I like.
Old 12-09-2022, 04:48 AM
Brentco's Avatar
Brentco Brentco is offline
I’m generally not a fan of putting modern stuff in these cars on principle, but a few years back I decided to install a keyless entry system, just for kicks. Now I couldn’t live without it. Everything is tucked away so no modern gizmos are visible, but it makes the experience of driving the car so much more seamless. I’ve used a couple of those dirt cheap Chinese keyless systems off of Amazon — $30 or less. They’re all essentially identical products, and they have all worked great for me. No reliability issues, always worked flawlessly, and from a very impressive distance. I have it wired in so both the key fob and the interior switch can control the doors, and I even have it wired to flash the lights on lock/unlock.
1976 Trans Am Buccaneer Red
468ci, 10.5:1 CR, 87 CC RPM CNC e-heads, HR 282/288, 230/236, 561/.573 lift, Johnson Lifters & HS 1.65 Rockers
Old 12-09-2022, 08:49 AM
The Champ's Avatar
After a 5 year search for the "right" rims for my wife's Camaro, I spotted the brand new (at the time - 2017), Billet Speciaties - Win Lite's. When I ordered them, I was told by my sales rep it was the very first set they had sold.
https://www.billetspecialties.com/st...eter-brs02-17/
Because she had most al of the chrome/stainless on her Camaro powdercoated satin black, she wanted a polished rim with black highlights.
She hates any of the traditional 5 spoke rims,
We went with 17x8 fronts and 17x9 rears with 235/45/17's and 275/40/17's.
The attached photo is with the old 16x8 Centerline 500's that we put on back in 2001. After 15 years of polishing around all those rivets, I needed something easier to polish!
The Following User Says Thank You to The Champ For This Useful Post:
Old 12-09-2022, 08:52 AM
Thank you for posting. Nice looking car. Nice you and your wife have cars.
Old 12-10-2022, 06:02 PM
NeighborsComplaint's Avatar
Take the car to an auto alarm shop and have them install a basic keyless entry kit. I think it's smarter to leave the install to them. The auto salons in-town here all use Viper brand. The passive system is their best seller but I would think with a vintage car you'd want the "point and click" show.
Triple Black 1971 GTO
Old 12-11-2022, 01:49 PM
I will 100% disagree ..
1. Would I want a kid doing my classic like they can rip off door panels on new cars? Why let someone take apart a car they know Nothing about? Hack, hack...
2. The Viper systems are for Modern cars and have way more cost and features than needed.
3. The MES system and others like it are so simple. A Relay behind glove box( Trunk) and and the controller by the fuse box and like 3 wire install.
4 NO car alarm place is going to take the time to research Anything on our older classics. So they gouge door panel? IF you can replace it its 9 months out and 500 bucks...... No thanks...
No offense Neighbors...
Old 12-11-2022, 04:39 PM
I had just the opposite experience when the car salon near me installed my stereo. They replaced the kick panels with my pre-loaded component speaker panels. Removed the passenger seat and installed my low profile powered subwoofer without a scratch. They even honored my request to connect both my rear quarter mounted power antenna and in-windshield antenna. They neatly fitted my head unit in a small console I adapted to mount inside the glove compartment. They're all gear heads and do this custom stereo all day long and were excited to work on a classic muscle car.
Your issue is thinking all shops operate like BestBuy. You just have to look around to see whether or not the know what they're doing. You can also remove your own door panels if that is a concern. I chose to provide them a precut glovebox liner, fitted console and unmounted glove box door, figuring reassembly would be more intuitive, not that it was brain surgery anyway. They looked at my less than perfect cut in the glove box back (which you'd never see) and proceeded to test fit, enlarge the opening slightly and then hot glue windlace molding around the opening to eliminate any gap. I was impressed.
Old 12-12-2022, 10:03 AM
I can see this, but most shops are all about the money and custom work is Not an option, nor do they have the skill.
I am hoping it wasnt too pricey. Glad it worked out for all you needed and your kick panels have plenty of gray caulk/ sealer around the big air intake area, especially where the cable for vent goes...
