SPEEDOMOTIVE CAMS
Anyone recall what brand cams Speed O Motive put in their “kits” circa ~1984? I know advertised duration , and lift. Like to find the 0.050 # and lobe separation. 280/290 .510 .536.
Thanks Luke |
http://www.classicalpontiac.com/restoration/cams.html A few older Speed O Motive cams on ebay and there all Wolverine brand. Its probably one of these listed.
Speed-O-Motive ceased operations almost 10 years ago. They specialized in selling stroker kits and engines and used cams from different manufactures including ISKY. And apparently the cams sold under the Wolverine name.
Thanks, this shaft is not in a Pontiac , FE Ford. Was a new cam, , around 1984 Purchased.
Then it could be using a higher ratio rocker arm. As we know most Pontiac cams are typically rated with a 1.5 ratio.
