Also need to say this is the 2 bolt style motor mount. Would the turnbuckle be an easy way to go for a little more support to take some of the stress off motor mount. Would I want to set it up with some slack or tight. The engine is already in the car with the solid mounts.
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
I'm wondering if this was why people started filling their block to combat the block flexing and stressing the main bearing? I have been using the 3 bolt system on my GP. Good information for sure.
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
I set mine with 1/8 inch of free play with a flexible mount, that gives some flexibility between the frame and engine, but limits it as soon as you twist the engine 1/8th of an inch. With solid mounts you already have all the stress on the block as soon as the engine accelerates, putting a turnbuckle on it with a solid mount is really going to serve no purpose. There needs to be some flexibility in the mount system so the force can be applied to some other portion of the engine other than just above the oil pan rail. The 2 bolt early style is what the Pontiac engineers were concerned about when they re designed the mount system, because it puts all the twisting force on 1 main bulkhead, #3. By putting a turnbuckle from the cylinder head area you're redistributing the stress forces to other parts of the engine, instead of applying all the force to the left center side of the block. If you ever compared Pontiacs mounting points to other brands, you'll notice most manufacturers used at a minimum of 3 mounting points, many use 4 points such as the LS engines. Pontiac used 2 mounting points for more than a decade, they were due for an update. If you're trying to use the 2 bolt system which was designed in 1959, and you're making 2022 power, you need some help to stop block distortion, 5-600 ft lbs is a lot of force to concentrate on 2 bolts, and one main bulkhead. I did a lot of reverse engineering, and studying when Pontiac changed their second design mount system, because frankly, I couldn't understand why the change happened. There is no record that I'm aware of that explains why the engineers changed their system. So i just started studying the changes from one system to the other to realize, how and why they changed it. The explanations I posted are my observations, and nothing more. I just studied the changes, and drew my own conclusions. I also studied the engines that have been posted on the net that could be attributed to tension being concentrated on the #3 bulkhead, and resultant damage incurred. There are more than a few engines that had failures in the #3 main area. Pontiac engineers did their homework, and succeeded with their improvements. We just need to follow the cue, and be aware of the damage that the early mount system can do when stressed to it's limits. |
Unfortunately it allowed a lot of engine movement (counter-clockwise viewed from the front of the engine) on acceleration. It also was a complex part for assemble on the line. The two bolt mounts clean that up a lot and if you use the simple retention methods provided in previous posts you are good to go. No stress applied to the block and a simple fix using a strap or turn-buckle. Tom V.
What would be the best course for a 2nd gen bird using a '72 block at the 575-650 lb-ft range? Won't be drag racing, but will do some autocross on modern street tires.
The car currently has oem style mounts that are new, but we've discussed using a chain or turnbuckle to the cyl. head. Block is not filled. |
You use the same mounts as the 69 GP in my signature pics. That car was my first use of turnbuckles on my race car. Both sides I used stock style mounts and because I was running it hard into the corners and lifting, then braking, I used 2 turnbuckles (one on left head as well as one on the right head) as there is some engine twist upon deceleration, and braking. I ran that car for 3 race seasons with the turnbuckles, no damage to engine, or mounts. I still have that engine in storage from the 1981 season, just as it came out of the racecar.
Your engine is already assembled, so nothing can be done about hard blocking, I've never used it in any of my engines throughout the years, because in the 70s and 80s no one was talking about it in Pontiacs at that time. I don't think it's a bad idea, just that I've never done it personally. It's used primarily to stiffen cylinder walls that may be thin due to core shift, or a large overbore. My own engines were all stock bores, as they were low mile engines. I always tried to run low mileage blocks that hadn't been bored, not realistic at this point in time because of the age of the castings. Back then I had a service manager at the local Pontiac dealership that used to keep me informed if he had any good blocks available from warranty, etc. |
Guess I was lucky...I ran solid motor mounts with a poly trans mount on a Jerico 4 speed/400/ 150 shot for several years. Ran a two step set anywhere from 4500-5500, block was (is) bottom filled. Made 600 RWHP and 700 TQ. I clicked on this since I have been thinking of going to poly mounts just to reduce/eliminate any harmonics/vibrations from the solid mounts since this is now just a street car
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
I have stock rubber mounts on both sides, with a solid rod going from head to frame on left side. It has been that way since 89' and trans brake the whole time
I run a front motor plate and stock rubber mounts as a limiter
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
