Old 11-22-2022, 05:54 PM
Scott Stoneburg's Avatar
Default Searching for a vacuum leak
I have 2 reasons I think I may have a vacuum leak, #1- sometimes, at light throttle (cruising speed) I have a distinct whistle #2- my AFR reading on my FAST meter at idle is 19-20, cruising it ranges from 16 down to 13.
To check this I had it running and sprayed Carb cleaner around the base of the carb and the intake flange. No noticable change to idle quality. Then I put my Moroso carb cap on the Dominator, it did suck the cap down and distort it. But the carb stud held it tight enough that I don't think it could have been sucking air around the base. The motor did not shut off. I guess it could be an internal leak in the carb. So 2 questions come to mind.
1- is there another effective was to search for the source of the leak?
2- If I used 3 circuit gaskets on the metering blocks by mistake ( this is a 2 circuit carb) would that cause an internal vacuum leak. I don't think I did that but I'm 2nd guessing myself now.
Old 11-22-2022, 07:07 PM
25stevem's Avatar
25stevem 25stevem is offline
Can you replicate the whistle with the motor out of gear?
How old is the carb, does the throttle shaft rock around?
I do stuff for reasons.
Old 11-22-2022, 07:31 PM
I've only ever heard the whistle while driving. I haven't really held it at rpm while in park to see if I hear it. The carb was rebuilt about a year ago. Just a clean and new gaskets rebuild here at my shop. It's had this whistle from the begining, I just ignored it until I had reason to suspect something is wrong
Old 11-22-2022, 07:53 PM
25stevem's Avatar
So if you completely close off the top of the carb with a big towel will it stall out?
Old 11-22-2022, 08:04 PM
bluegoat65 bluegoat65 is offline
Does it whistle when you shut down? Like a compression leak thru the valve seats. Or only when running or both? I ve only heard that when running, using 4150s when the throttle blades have the holes drilled in them to get the transfer slots in the correct positions. One is set to low and the air is being drawn thru the holes heavily. I know thats old school tuning, but thats how we did it...lol.
Old 11-22-2022, 08:42 PM
I didn't use a towel, I put the blue Moroso carb cap on it. It stayed running.
Only whistles while driving. Not at idle or on shut off
Old 11-22-2022, 08:55 PM
I see what your sayin about the blue cap now. Jeez you gots a serious leak. Check those metering block gaskets. Happened to me. But can t remember what it exactly was doin, it just was runnin like chit. The one hole exposed another. It may have been the air bleed channel. You ll find it, ugh, just gotta take things apart in reverse of how it went together. ✌
Old 11-23-2022, 12:20 AM
mgarblik mgarblik is offline
From your description, it sounds like it's getting combustion air from somewhere. Not familiar with your car, but power brakes?, Some type of PCV system? These would be air leak sources.
Old 11-23-2022, 10:30 AM
ta man ta man is offline
I have had whistles from loose fitting on brake booster.
Old 11-23-2022, 10:18 PM
No power anything, not even a vacuum port in the manifold. I'm thinking must be internal in the carb. Or maybe the intake gasket? Not sure if a leak there would do this or not.
Old 11-23-2022, 10:50 PM
slowbird's Avatar
slowbird slowbird is offline
No idea about your engine specs but rocker cover bolts go into intake ports? Might be leaking there.
Old 11-24-2022, 12:02 AM
Mike S's Avatar
Mike S Mike S is offline
Late last year I was coming back to the pits and noticed a whistle sound from the engine. Mine did it at idle and cruise rpms. It was more prominent on one side of the engine. In my case it was the intake gasket. It actually sucked in.
Old 11-24-2022, 10:53 AM
Looks like I'm gonna pull the carb and rebuild, if it continues then I'll take the intake off to check the gaskets there. Dang..lol..
Old 11-24-2022, 11:20 AM
stags's Avatar
stags stags is offline
Had an intake leak few years ago on my Firebird. Never heard a whistle but my time slips told me something was wrong. It was on the low side and wasn't obvious when trying to locate it with a spray. When we pulled the intake a sharp eye (not mine) noticed a slight stain under #3 port. New gasket solved the problem.
Ain't as good as I once was, but I'm as good once as I ever was.
Old 11-24-2022, 11:43 AM
Check all your plugs that may give you an idea where to look. Are your heads ported enough to where the valve cover bolts need sealant or could cause a vacuum leak?
The Following User Says Thank You to ta man For This Useful Post:
Old 11-24-2022, 06:11 PM
Using CV1 heads. I don't remember the valve cover bolts going into the ports
Old 11-24-2022, 06:54 PM
tom s tom s is offline
Scott,do you have a spare carb?Maybe swap it out first to maybe rule out the carb?Tom
Old 11-24-2022, 07:51 PM
I had a buddy in college with a 383 Cuda that one Holley he had whistles on light acceleration, swapped to a different carb and no whistle.
Old 11-24-2022, 08:27 PM
beemergary's Avatar
Use kids bubbles and blow air to find leaks around gaskets,
