For the Pontiac faithful.......
.....hopefully, every little bit helps.
Was not sure where to put this. A 67/68 Firebird Ram Air bottom pan on an AMC 413 (401 + 0.060") Jeep YJ. Ignore the TJ grill, doors, etc..... Its a frankenstein Jeep. *Top carb hat spacer required to get the pan to where I wanted it to sit.
79 Trans Am WS6 71 Formula 72 Formula 71 Firebird 69 Firebird |
Why not go all the way and put a Pontiac engine in too?
I've done 4 swaps from AMC/Jeep to Pontiac Stratostreak V8s. 65 Wagoneer from 230 OHC 6 to 389, 67 Wagneer 327 Packard/AMC to 389, 73 J4000 PU truck 360 AMC to 455, and a military M-715 5/4 Ton truck from 230 OHC 6 to a 455. I've always toyed with the idea of doing a CJ/Wrangler Jeep swap, but never was in the position of owning one. |
I'm a semi purist I guess.
AMC "belonged" more in the Jeep, once I determined the straight sixes (4.0 and 4.2) and the V8's shared the same bell housing pattern. I hear you though. I toyed with the idea of the spare Pontiac 428, as well as a having another spare AMC 401 for another project.
Nice Jeep! They're certainly a fun truck to work on and play with. Nice looking setup!
I got a TJ myself.
Thank you. Yes, they are fun and living in an area w/o emissions and engine transplant controls, it was straightforward.
Its "beef" across the board. Very little weak links now. Just another play thing though. Bad weather, off road winter deal. I should have used the narrowed 35 spline D60 for the 69' Bird but switched gears.
You're just proving the point.
AMC = All Manufacturers Combined |
