Dumb Question #37
What are you supposed to use to get out the square drive plugs in the back of the block and at the distributor oil pressure hole? They look like about 5/16". 1/4" = too small; 3/8" = too big. Never had a 5/16" square drive!
Don't want to FUBAR the plugs. What's the best thing to use? Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi. “Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill |
I've heard of guys grinding down a cheapie 3/8 extension to fit as tight as possible.
I've never had to pull plugs out yet, I would make sure the fit is as tight as possible and the cheap tool is strong enugh not to break off in the plug. Maybee some one has a source for the tool , a Plumbing valve seat tool might be the right size, Use plenty of penetrating ouil on the plugs a few days before trying to get them out, squirt them every day and let sit. Any engine builders have any better tricks than this?
Jason Rackawack 1975 455 Trans Am - 1975 Firebird 400 |
Find a tool vendor snap-on, matco, tools are us, whatever but they do make square drive sockets (just like torx or hex drives) in different sizes.
Find some 5/16" key material or square stock at Home Depot for X $ per inch. Them just use a vise-grip or 5/16" open end wrench to turn. Make sure to soak w/ penetrate oil and beware if using non-key material as the steel you will get at HD is probably pretty soft, but it should work.
The joker in the deck keeps sending me his card. Smiling friendly, he takes me in. Then breaks my back in a game I can't win. |
Thanx guys.
I hadn't thought about key stock. No problem to get that around this area. I'll give it a go. Stewart
I used the blunt end of a cold chisel and a crescent wrench.
1967 Firebird Convertible Factory 400/4spd Now 462/5spd Fuel Injected http://1967firebird.atwebpages.com/ |
Another good idea which won't cost me anything. No chisel, but a punch is just as good!
Thanx Hammered. Stewart
I just got the square drive sockets sleepy mentioned,forget what brand they are,likely mac or matco.
Those are 1/2" drive sockets,so I can use my long snap-on breaker bar with them too. But even with those sorta dedicated tools,there can be some tough removal jobs. |
I grind down the end of a grade 8 bolt (very high tensile, with 5 dashes on the head), so it is very snug and has to be tapped into the plug. Then a 1/2" socket and breaker bar.
If you are trying with a home made tool I would go with the ground down socket method. I have one in my tool box just for that purpose. If you want to try square stock you better make sure it's hardened our you will turn it into a corkscrew. HTH
North Dakotas fastest REAL GTO 10.10 @ 131 MPH in the 1/4 Hoping to get it back together some year. www.jandjrepairandrestoration |
Six marks.
