I just picked up a 4bl for my Lemans and will finally get rid of that 2bl, but was wondering how thick of a gasket should I run between the carb and intake? The carb is an Edelbrock with a stock cast intake and the gasket that came with the carb is paper thin! Is this ok? I do not want to deal with possible vapor lock issues next summer if the carb is sitting too close to the intake.
My other life has meaning....
"It beats pickin' cotton and waitin' to be forgotten" |
I like to run those isolator type gaskets. They are 1/4" thick or so. Probably more important on an iron intake, but I've never used anything different so I can't say for sure if the thin gasket will be a vapor lock problem or not.
Brakes?! We don't need no stinking brakes!
Never trust a fart. They sometimes suprise you. http://community.webshots.com/user/motornoggin http://motornoggin.smugmug.com/ |
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Bigger than a quarter inch? That's all I've ever ran as well.
Should I go with a spacer, or just a thick gasket?
THICK GASKET alone or ..............1/2 - 1" spacer w/thin gaskets
http://www.kingofgtos.com/index.htm
http://www.stockappearingdrags.com http://www.stockappearingdrags.com Come on get off that lawn chair and drive that car like it was meant to be driven. 69' 400 RAIV Judge Conv... 12.86@107 Factory Stock 69' 400 RAIV Trans AM .....12.48@110 Factory Stock 69' 400 RAIV Judge HT..... 13.07@104 Factory Stock 73' 455 SD Trans AM........13's?? not run yet 66' 455 GTO Convert.........12.20@112 non original 63' 421 SD Catalina...........restored fast as h*ll |
Gonzo, any advantage to either setup? Does it matter?
