Old 02-04-2002, 06:34 PM
bigunde bigunde is offline
i got a 66 tempest that all of a sudden something is killing the battery.i have a 455 and have a relay runing the hei.i thought that was it,but i unhook it and rub the positive cable over the battery post and there is still some faint sparks.i dont have a rally clock or anything of the such.the altenator was acting up while this was going on so i replaced it.same thing and now when i run the car a few minutes,it doesnt want to shut off right away when i turn off the key.HELLLLP>
Old 02-04-2002, 07:01 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Your on the right track by rubbing the pos. cable and checking for sparks. Pull one fuse at a time and rub the magic cable. When it stops sparking you will know what circuit to work on. At least you will have a general idea on area of the car to start checking. Good luck.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 02-04-2002, 08:35 PM
Carl Carl is offline
Disconnect the negative battery cable and put a test light between the cable and the negative post on the battery. If you have a draw the light will light. pull fuse untill the light goes out and that will tell you where the draw is. Something to think about is what have you added lately that would cause this problem? If you need anymore help feel free to email me.
Old 02-04-2002, 08:42 PM
Two more things to check. Does the alt light stay on when the key is off? If it does the unit has a bad diode in it and will make the car continue to stay running when the key is off. Check the voltage regulator and the wiring to the regulator. Put a volt meter on the battery and see what the voltage is. Should be 13.6 to 14.2 volts. Turn the headlights on and see what the meter does. The voltage should drop for a secound then climb right back up. To check the regulator and alt properly to have to full field the alt. At 2000 rpm it should put out the amount of amps that is stamped on the alt.I have found that many of the old mechanical regulators stick and cause alot of problems. You are better off with an electronic one. Hope this helps you.
Old 02-04-2002, 11:42 PM
Half-Inch Stud's Avatar
yea, what Carl said.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 02-05-2002, 01:32 AM
george kujanski's Avatar
I assume you have a mechanical regulator. Remove the battery wire (terminal 3) from the regulator. If you have a stuck relay in the regulator, this will remove the source of your current drain.
What happens in this case is that the battery wire backfeeds thru your idiot light and actually powers the circuits conected to the ignition side of your switch. Since you also are using a relay for the HEI, the relay requires a lot less voltage (and current) to stay held on and the backfed current thru the idiot lite apparently is enough to hold your relay on. Pulling the idiot lite wire (terminal 4) should do the same thing (removing the backfeed).
Regards, George
Old 02-05-2002, 02:27 AM
Bob Dillon's Avatar
Bob Dillon Bob Dillon is offline
Location: Gilroy, California, USA-Garlic Capital of the world!
I hate electrical problems. Ir's nice to have guys here who understand DC systems. I think life is too short for me to learn.
"Democracy is a beautiful thing, except for that part about letting just any old yokel vote."
~Jack Handey, Deep Thoughts
Old 02-05-2002, 12:40 PM
Electrical problems are not that hard to diagnose, but without a wiring diagram they're near impossible to figure out, especially with modern cars. I invest in a service manual everytime I get another car.
Regards, George
Old 02-05-2002, 06:33 PM
Thanks a thousand times over for the great advise.I am going to try and work on it tonight
or tommorrow night.I will let yall know what i found out.Thanks again..bigunde
Old 02-10-2002, 10:45 AM
ok guys,i found the battery killing culprit.it was the dome light fuse.crazy thing is that there in no bulb in there,do to the fact that i couldnt get it to go out a long time ago.i had replaced the door switches and sometimes they would go out and sometimes they wouldnt.no biggie.i am going to take the car out for a
spin today and will let yall know if it keeps running with the key off.thanks again for all yalls help.
