Old 02-05-2002, 04:45 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
The 400 fits in my 88 bird but I must move the oil filter. I was thinking of getting a plate/adaptor made with 2- 45 degree fitting coming off it to replace the oil filter adaptor on the motor. I was thinking about mounting the filter on the firewall where the heater assembly was. Looking at my setup I don't think I have the room to use the stock oil filter adaptor with a filter relocation kit. I was also thinking of using this type of setup in my 68 Bird. Any problems with my thinking?
Alan
PLAY400's Avatar
Alan
Old 02-05-2002, 04:55 PM
Goatman Goatman is offline
On Vacation
You could just tap the block and run your fittings right from the block instead of using an adapter.
Old 02-05-2002, 04:58 PM
Half-Inch Stud's Avatar
Just do it.
My 69 Firebird oil filter sits on the Passenger inner fenderwell. Pretty easy to change.
Be sure to keep the In/Out hoses correct with the filter in/out. My Delco filter features a one-way valve to stop backflow...that means no flow if the hoses are swapped.
H.I. Stud
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 02-05-2002, 05:55 PM
PLAY400's Avatar
I was thinking about tapping the block but I thought that I would have to use fittings with a smaller ID which I thought could reduce flow. I was going to use fittings that had the same ID as the ports on the block. Or should I use slightly larger fittings?
Alan
Old 02-05-2002, 06:14 PM
On Vacation
Go with slightly larger ones. I see that they now have "wide mouth" fittings for fuel pumps and oil systems. Use those as thier inner diameter is sure to be enlarged.
Old 02-05-2002, 07:50 PM
I assume you are going to remove, strip, & clean the block after you tap it?
Don't even think of not doing it! You'll be sorry.
Old 02-06-2002, 10:18 AM
PLAY400's Avatar
Thanks for the input. Since the motor is going to be variable in my case I will be making a bolt on adaptor. should make engine swaps easier.
Alan
Old 02-07-2002, 02:42 AM
WARPed's Avatar
WARPed WARPed is offline
Make sure you use #10 lines and full flow fittings, no angled adapters stuff, example: #10 45degree to ½” pipe fittings. Any “adapting” is done with straight adapters only. This will cost more but it will be done right, the first time. Doing it any other way is a false economy and the Fram commercial “pay me now or pay me later” applies. BTW, don’t use Fram filters, nice commercial, crappy filters nowadays.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 02-07-2002, 10:31 AM
PLAY400's Avatar
Hey WARPed, am I to make all my bends with just the hoses? I don't think I have enough room to come straight out of the block and make a graceful bend up. Frame is right there on the 88. I assume no hard bends are allowed with the hose. I was hoping that I could use 45 degree fitting on the block and filter adaptors
Alan
Old 02-07-2002, 12:27 PM
Cobrabill Cobrabill is offline
Location: The Palomino Ranch in Tucson-where the real horsepower lives.
Check out www.cmfilters.com
Old 02-08-2002, 09:22 PM
WARPed's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by PLAY400:
Alan
<HR></BLOCKQUOTE>
What I mean is do not make your turns with an adapter. Look in Jegs and you will see flare-to-pipe adapters, you would not use say part (Russell #’s)#799-660970 to do the job. You would use a #799-660500 (straight) to the block side and then use a 45 hose end #799-610110 to make the turn.
1994 Formula
Old 02-11-2002, 05:04 PM
Maniac Maniac is offline
I bought an oil filter relocation kit and couldn't stop the hoses from leaking. No matter how snug I got the hose clamps, both tubes leaked frequently from the end closes to the engine. My dad's friend recommended that I go have a hydraulics shop make me a pair of crimped hoses set up to handle 80lbs of line pressure. Said that would stop the problem. I ended up putting the original oil filter setup on since I'm planning on selling the car and didn't want to mess with it anymore.
Many have tried to prove that they're faster,
But they didn't last and they died as they tried.
Hell bent
Hell bent for leather
Old 02-12-2002, 01:34 PM
PLAY400's Avatar
Hmmm Is there any reason I can't use 1/2" hydraulic hoses and fittings?
Alan
Old 02-13-2002, 03:04 PM
WARPed's Avatar
If you are going to run the car at the track (NHRA or IHRA), and they see that setup they are not going to let you play.
1994 Formula
Old 02-14-2002, 02:11 AM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
I bought the relocation kit as well, tossed the rubber hoses and 2 cent clamps in the trash, and as much as I hate the stuff, I used steel braid with #8AN to the filter (HP1 which are nice because you don't have to special order them} up to a cooler then back into the motor. I wanted a cooler for our 150 mph 90 mile runs in the 110 degree dessert. Works great, ran about 3 degrees cooler at 145mph than it did last time. Now I am also using the 80psi oil pump. I don't know what the pressure drop is but I have not had any measurable drop at the gauge. I also used an inside flaring (20 degree taper) tool to bore out the AN fittings and remove the 90 degree angles.
TigerEFI.com (Classic Pontiac Fuel Injection)
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
