Old 03-22-2022, 01:12 PM
napster's Avatar
napster napster is offline
Default Value of #48 Heads
I purchased #48 Heads back in 2010 from a member on this board back in 2010. My intension was to use them on my 1969 GTO once I got the engine rebuilt. I knew the original head were really beat up from detonation, so I wanted better heads as replacement.
Well, a lot of time gone by and only now am I getting the engine rebuilt. I am not using the 48 heads since I purchased some RA II heads That will go on the rebuilt engine.
What are a good set of 48 heads going for these days?
Thanks in advance.
The Following User Says Thank You to napster For This Useful Post:
Old 03-22-2022, 02:50 PM
tom s tom s is offline
Bare set on ebay for $700 OBO.Tom
Old 03-23-2022, 07:41 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
aren't 48 the same as a 62
Old 03-23-2022, 08:47 AM
I have a set of nice 48s ready to go for $1000.
Clean, Rebuilt, tall-ported, the wider angle keepers, New GTO Chrome Valvecovers with thick gaskets. No rockers though (extra)
If these sell then my Spare 455+030 shortblock also is avail.
Old 03-23-2022, 09:29 AM
They are the same UNLESS you need 48s.Tom
Old 03-23-2022, 10:36 AM
48's have a 350 chamber, 62 has a 400 chamber. this can be seen when placing a gasket on them.
2007 Grand Prix GXP 5.3L
The Following 2 Users Say Thank You to 74Grandville For This Useful Post:
Old 03-23-2022, 01:00 PM
Brianbigoats Brianbigoats is offline
I sold a set for 700 a few months ago
Old 03-23-2022, 03:39 PM
Kenth's Avatar
Kenth Kenth is offline
Lots of 48īs on RAIII and M/T 400 engines.
And, on 350 H.O. engines as well.
Same 66-68 cc chambers as 1970 #12 heads.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-23-2022, 03:41 PM
Kenth's Avatar
Nope.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 03-23-2022, 03:53 PM
Formulabruce's Avatar
Have cc'd a few sets of #12 heads, seems they were 72 cc on average...
Old 03-23-2022, 05:57 PM
My 48s are 72CCs.Tom
Old 03-24-2022, 05:01 AM
Kenth's Avatar
Adding pictures of #16 H.O. heads and #48 and #12, all said to be 72 cc.
Which of course is not the case, plain to see by just a look.
If anyone has pictures of two differently factory machined #48 heads, one 72 cc and one 66 cc i would certainly would like to see those.
And, adding an excerpt from the 1970 performance catalog.
Name:	#16 J118 4.jpg
ID:	587028   Click image for larger version
ID:	587029   Click image for larger version
ID:	587030   Click image for larger version
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 03-24-2022, 06:27 AM
25stevem's Avatar
25stevem 25stevem is offline
A drop from near 76 CCs to just over 66 CCs makes for a much greater compression increase then a 1/4 point!
I do stuff for reasons.
Old 03-25-2022, 09:10 AM
mysticmissle's Avatar
I see some machining differences, but can you cc all o f them? even if its a rough estimate?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 03-25-2022, 10:10 AM
Im building another engine right now with stock 48s and the chambers are 69 CCs.Tom
Old 03-25-2022, 05:50 PM
Kenth, those 16 chamber scallops look non-stock to me. I've owned the (good) 16s from 1968 and they had chambers like a 48 & 12.
I've seen the (nosogood) 16s from 68 with the Cast AIR injet ridge (like 670s have), and they too had the good chambers.
ah geez my 48s chambers measured 78c: with ferrea valves and chambers modified (unshrouded intake and exhaust, scallop subdued on intake and exhaust, and squish end smoothed at exhaust valve)
Old 03-25-2022, 07:34 PM
SD455DJ SD455DJ is offline
For what it's worth, we cc'd the combustion chambers on a #12 head (looks like it had one .010" cut in its life) and a truly never cut #216 casting date H157 (from a 1968 428HO/M21 Catalina) which became just #16 later in the year. The #12 measured 68.6 cc's and the #216 (aka #16) at 74.8 cc's. I imagine the #12 head started out closer to 70+ cc's originally.
Name:	CC No, 12 Head 003.jpg
ID:	587128   Click image for larger version
Name:	CC No, 216 Head 002.jpg
Old 03-26-2022, 01:35 PM
android 211 android 211 is offline
The application for 48s is 4 speed and Ram Air III. Also 350 4bbl HO. 62s go on standard 350 hp automatic 400s and Grand Prix with 400 or 428 automatic.
Pontiac made over 50,000 automatic GTOs in 69 with the standard engine, far fewer 4 speed cars.
Old 03-26-2022, 02:59 PM
25stevem's Avatar
If I am not mistaken the only time a 48 casting was used along with a auto trans was with the 69 350 HO motor .
All other 400 4 bbl motors that where not RAIII 4 speed cars Got the 16 casting in the GTO and the GP, and all other 400 motors with a 4 bbl got the 62 casting.
Old 03-26-2022, 03:03 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
All other 400 motors that where not RAIII 4 speed cars Got the 16 casting.
Not exactly. 69 4 speed cars got the 48,s even without ram air. The 16 casting is a 68 casting. In 69 all the base automatic cars got 62 heads.
