Torque Spec - 400 - Fan Assembly to Water Pump
Hi Guys, the 4 nuts that attach the fan to the studs on water pump. I can't find the spec. Anyone point this out in the shop manual. Thanks!
Unlike engine internals and other sensitive areas, I don't feel like this is something which warrants being finicky with torque specs. Just snug it down appropriately. You can use threadlock if you are paranoid.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
thx
What kind of setup has studs on the pump flange?All of mine use fine thread bolts?Tom
To answer the OP's questions, just tighten them down without going gorilla strength on the nuts. I use lock washers between the nuts and the fan hub.
'70 GP Model J 462 Butler ported 87cc Edelbrock D-ports RPM intake with Holley Sniper 2 CompCams 236/242 hydraulic roller Tribal Tubes tri-y headers TH400 13" Continental "Jim Hand Special" 3.50 9" CurrieTrac, 245/45-18 Front, 275/40-18 Rear |
EGAD! I just read my '70 shop manual which references "Bolt-Fan and Pulley to Water Pump" 20 lb-ft. That being said, every one of my Pontiacs in the past has had a stud and nut setup on the fan mount. How long of a bolt do you use?
And I see Ames sells both bolt kits and stud & nut kits. They say "check your original before ordering."
Thanks!
Is this a clutch fan application!I have never used a clutch fan.All of mine use a fan blade to a spacer with bolts holding them to the water pump flange.Tom
I pull on the wrench until my wrist says, "That's plenty tight"...………….
77-78 TA clutch fans with studs are OEM. |
Got it.Tom
My 64 uses bolts
Make sure your split lock washer end is not in the slot opening of your clutch fan. It should be located on solid material.
