Old 04-07-2024, 09:39 AM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by gman005 View Post
New cam, steel rods and heads.
Compression the same? Heads same except new?
If those are same and basically just the cam change I'll guess 940-950
Old 04-07-2024, 09:57 AM
Scott Stoneburg's Avatar
New steel rods? Did you have Aluminum rods previously?
Old 04-07-2024, 10:49 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Why that 113 on that cam?
Pp.
Hi Steve.... That 113 is the intake centerline
Go fast, see Elvis!
Old 04-07-2024, 12:52 PM
Gary H's Avatar
Gary H Gary H is offline
117 LSA on the cam. I'll say 1020 HP.
Old 04-07-2024, 01:31 PM
BILL BOWMAN1's Avatar
BILL BOWMAN1 BILL BOWMAN1 is online now
I thought it read .630 lobe-old eyes! I’ll still say about a grand!
Old 04-07-2024, 07:15 PM
gman005's Avatar
gman005 gman005 is offline
I'm not going to post any numbers but it was down 50hp with this cam. I'm going to make a few passes with it and see then put the old cam back in.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 04-07-2024, 07:38 PM
slowbird's Avatar
I ran pretty much that same cam from lsm in mine, ran great. Sucks it didn't work out for you. Good luck this season.
Old 04-07-2024, 09:38 PM
PAUL K's Avatar
That's disappointing..... Sorry to hear that.
Go fast, see Elvis!
Old 04-07-2024, 10:14 PM
That stinks bro, get a couple of runs to make sure the Dyno wasn't having a bad day
Old 04-08-2024, 08:58 AM
Stan Weiss's Avatar
From my standpoint it is hard to say what is happening due to lack of specs.
535 ci
1) 920 HP (what RPM), 278 intake and 292 exhaust on a 114 cl (what LSA), what heads (flow and valve size), what CR
2) 870 HP (what RPM), 284 intake and 306 exhaust on a 113 cl (117 LSA), what heads (flow and valve size), what CR
Do run a power adder on this engine?
Stan
Pontiac Pump Gas List
Old 04-08-2024, 09:52 AM
slowbird's Avatar
535 ci
Stan
Not sure if he'll post much more info. But looking at the differences in the heads before and now would be a good starting point imo. He stated only changes were cam, rods and heads. Out of those 3 I'd pick heads as the issue. But not much info to go on here.
The Following User Says Thank You to slowbird For This Useful Post:
Old 04-08-2024, 10:28 AM
gman005's Avatar
The new heads are supposed to be the 430 cnc port from Kauffman same as the old heads. Compression is at 14 to 1.
71 Lemans Sport.
72 Lemans Sport.
Old 04-08-2024, 10:41 AM
gman005's Avatar
The new heads were bare and everything was transferred from the old heads to the new heads.
71 Lemans Sport.
72 Lemans Sport.
Old 04-08-2024, 11:27 AM
Stan Weiss's Avatar
At what RPM does the engine my 920 peak HP?
Stan
Old 04-08-2024, 12:08 PM
gman005's Avatar
7200 rpm
71 Lemans Sport.
72 Lemans Sport.
Old 04-08-2024, 01:36 PM
Money Pit's Avatar
Money Pit Money Pit is offline
Your new cam is virtually the same as my Bullet nitrous cam. I'm running 1.75 rocker ratio. My LSA is 115 installed at 113.
Old 04-09-2024, 03:56 AM
gman005's Avatar
I am going to do a leak down test today after work.
71 Lemans Sport.
72 Lemans Sport.
  #38
Old 04-09-2024, 05:49 AM
steve25 steve25 is online now
I was going to say what Slowbird did, the heads are the issue.
If your leak down test shows ok then why even go thru the work of putting the motor in the car to make a few passes if the new motor is not even the equal of the old one?
I guess your stuck with it for this race season, or do you still have the old heads?
  #39
Old 04-09-2024, 11:38 AM
grandville455's Avatar
That’s a bummer John! Where did the new heads peak this time? Same dyno as last engine? Can u share any of the dyno sheets maybe there’s something there that will help decipher what happened
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
  #40
Old 04-09-2024, 11:44 AM
I would also like to add to Stan's list of questions if you know how much vacuum was made at peak hp and the BSfC numbers from the dyno sheet?
