56 316/317 crank in a 301-T block ?
I found a local cool patina 56 Chieftain for a buddy and he picked it up last week. I was just curious if anyone has looked at thrust bearing dimensions to see if the 56 forged steel 2.5" mains 3.25" as a stroker crank to swap into a 301 Turbo block with its 2.5" mains ? just a random idea thats all.. I know the flange pattern could be a problem though I guess
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
Larry,301s are 3 in main and the thrust is more narrow.IF your crank is indeed a forged one(most are)you can have the mains welded too 3in and have the thrust welded to fit the 301 block.Another option is to have the mains welded and have a spacer shim made to make up the diff.If you check my original 383-301 build on this site you will learn about the shim.My latest build is using a 3.75 stroke forged 3in main crank.I had the rods cut to BBC size and had the thrust welded to avoid the spacer issue.IMO .250 stroke increase is not worth the effort.My cell is 5622430570 if you need to chat.Also remember if your going to put non 301 heads on the block there is a gasket issue which you will also see in my first build.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
