The 421sd in my 63 tempest does't want to start after 180 degrees. The hotter it gets the worst it gets. It trys to fire and seems to want to kick back. Was running 18 initial and went to 14. Plugs aren't wet. Gave it a light shot of starting fluid tonite and with a little cranking it started. Starts great when cold. Want all the bugs out before NORWALK (HELP) THANKS
Look into remote starter solenoid, heavier battery cabling, hi torque starter, an 850 to 1000 cca (cold cranking amp) Battery and plenty of GOOD grounds! (engine to chassis & chassis to body) almost more important than everything I've listed prior! So whats your current set up? What are you working with now?
Its the timing alright.
NHRA tech. "Its just a 412, I swear it". Pontiac tip of the year, quit those damn cigarettes. ![]() |
Try adding an ignition interrupt switch. Get the motor spinning, then turn the ignition on. Or pull some timing out while cranking if your box will allow it.
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
What starter are you using ?? A good quality Nipendoso/race mini starter really help with cranking. By all means rig a remote solenoid. Like Slick1 said....check your grounds!
I use all the above mentioned remedies and my 13.8 CR 508 cranks fine...hot or cold. My timing is locked out at 32 & box pulls 20 out while cranking... Good luck..Norwalk is near !!!
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. ![]() Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
I use these, http://www.madelectrical.com/catalog/st-1.shtml
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
Going to try a bigger gauge hot wire to box. I drive this thing on the street so it has time to absorb some heat under the hood on a 80-90 degree day. 63 tempest 421-980 heads-859 2x4 intake This thing would have been a real grin in its day
...It's a real grin now, Gary...
![]() Good luck - K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
What he said!!!!!!!!
![]() ![]() ![]() ![]() PHILLYGOAT
PHILLYGOAT 1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/ 3550lbs/ Full Exhaust/ Foot Braking 1.41 60ft 6.45@104.97mph 10.25@127.12mph(Pontiac Heaven) ![]() More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379 GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4 |
If your battery is in the front then use what i posted above, if your battery is in the rear (trunk) then you will need this.
http://www.madelectrical.com/catalog/tm-1.shtml
