Old 08-07-2008, 05:48 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Premium unleaded at $4.40 and E-85 at $3.09 makes the actual savings about 23 cents per gallon. Hardly worth it if you take into consideration the extra amount of fuel you have to move, and consume, to make up the difference.
We have been in contact with quite a few folks using the E-85, and not a single one to date is seeing any real savings from doing so, at least in street driven cars and trucks.
It's also way too early in this game to know how bad the E-85 really is on the entire fuel system? If it ends up eating up a $1000 carburetor in 2-3 years, or all the fuel lines, tank, or the fuel pump, etc, factor that into the cost savings, and there woln't be any savings.
There is also the potential for cylinder "washing" and dilution of the engine oil, when we start adding that much fuel to the incoming air.....FWIW.....Cliff
Old 08-07-2008, 12:21 PM
79TA455STROKED's Avatar
79TA455STROKED 79TA455STROKED is offline
Again,im not really thinking of it for savings.
23 Cents would be nice but even if it turns out the same cost as super unleaded,thats fine.
Im looking at it as i wont have to worry about detonation for the same price or 23 cents less a gal if you figure in the extra volume needed.
I need a carb and fuel pump/reg anyway.
Ill buy a fuel/pump reg that can handle alcohol.If it can handle alcohol,it will have no problem with e85.
As far as fuel lines,i have all stainless braided which is fine for e85.
Jeff,please pm me with a price on a custom Bandit edition 1050 dominator.
If you need the new combo details,just let me know.
Thanks!
9.81 at 139.89mph
3400lbs
Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS!
370cfm butler eheads
port matched victor
1095 king demon
4.30gear,th400
MICKEY THOMPSON DRAG RADIAL tire
Old 08-07-2008, 02:36 PM
rad400 rad400 is offline
Jeff nice work on the carb looks great, and Iam sure it will proform as well as it looks.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 08-07-2008, 04:23 PM
shaker455's Avatar
shaker455 shaker455 is offline
Thanks Conrad,
Runs good but I'm going to do a little wideband testing next.
Old 08-07-2008, 04:40 PM
Tom Vaught's Avatar
Boost Engineer
Obvious that if you posted at 4.23 today that you are not coming to Norwalk. Sorry we cannot have a nice meal with Cliff, Debbie, and the rest of the people from last years get-together.
Keep building those great carbs.
Tom V.
Old 08-07-2008, 05:02 PM
shaker455's Avatar
Well Tom,
Last year we left for Norwalk on a Friday afternoon so there still is time!...LOL
Old 08-10-2008, 07:57 PM
shaker455's Avatar
Thumbs up Update
Thanks for the compliments!
After dialing it in on my car the throttle responce is smooth and crisp, something you'd expect in a smaller 4150 style unit.
WOT performance revs up fast and pulls hard!...something you expect from a Dom.
Overall one of the best Dom's I've built with many new mods & much higher levels of adjustability than any other brand unit I've encountered.
Last test will be plugging in the wideband to varify A/F @ idle, transition, & WOT then off to its owner!
Good luck Brad! this one was worth the wait!
Jeff
Old 08-10-2008, 09:48 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Shaker, do you think a dom can be built to run as good as my 850 on the street and track? I am upgrading heads in the spring and thinking about going Dom but it would have to perform well on the street primarily.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 08-10-2008, 10:35 PM
shaker455's Avatar
Thumbs up Street Fighter
BILTIT,
This new Dom is living proof that you can have perfect street maners without giving up the punch of the biggest carb ever built!
The external linkage is one of the key factors as it is set up to work the throttleblades like a 4150 which allows more primary throttleblade movement for street use.
I've done extensive testing, research (Tom Vaught) and mods to each circuit to eliminate the typical Dominator characteristics that make it less desirable for "REAL" street/strip use.
Here's a pic of it running adapted to my RPM intake for testing.
Name:	sony camera 2 097.jpg
Old 08-10-2008, 11:06 PM
440GP69's Avatar
440GP69 440GP69 is offline
Are you for real that works good on a dual plane? Awesome!!!, Jeff i can't wait to give you a call and have you build me one! Nough Said!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 08-10-2008, 11:45 PM
shaker455's Avatar
For Real!
And yes it works great on my dual plane.
The right gaskets and adapter plate and your off....
No shaker scoop when I Dom test and lately I haven't had my scoop on much!...its collecting dust.
Old 08-11-2008, 12:06 AM
440GP69's Avatar
I have never seen someone do a 4500 on a rpm intake, How much hp and tq difference between that an say a 750 holley?
Old 08-11-2008, 05:05 AM
shaker455's Avatar
I never chasis dynoed the differance between the two on this set up as it is a test platform but I can tell you the engine responds more favorbly to the Dom.....the differance is night and day.
Old 08-11-2008, 07:42 AM
hectore3 hectore3 is offline
That's a nice setup. Who said carbs are dead?
Old 08-11-2008, 07:51 AM
BDHABT's Avatar
BDHABT BDHABT is offline
Shaker built my Dominator,ran great on the street;idled in gear @750rpm.Great vaccum also.Went quicker at the track.Best 60ft ever.All around,a vast improvement.
Mark.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
