When I bought my 69' Catalina, it had the 2 barrel, 8:1 Compression motor. Basically the weakest one you could pick from. Since then I've rebuilt it and want to compare all the components that I have on now to the stock ones. I want to know what duration the stock cam was in this engine and what the valve lift numbers are. If anyone could provide me with the information I'd appreciate it.
Many have tried to prove that they're faster, But they didn't last and they died as they tried. Hell bent Hell bent for leather |
Maniac, Here is two 69 400 2bbl 8.6 engine specs. (1) 265 hp 400 auto tran. YA block code, 8.6 c.r. cam 254, headcast 45, carb. number 7029060-70 (2) 265 hp 400 auto trans.,YB block code, 8.6 CR, 254 cam, headcast 45, 1-2 carb. number 7029060-70 The cam 9777254 (U) specs. Intake Dur. 269, open 22, close 67 lift, .374, Exhaust Dur. 277, open 72, close 25, lift .406 ,overlap 47. The YA engine has 30 degree intake, and the YB engine has 45 degree intake. Hope this helps, Floyd Hand
