Closed Thread
Old 07-10-2022, 04:37 PM
Gach's Avatar
Gach Gach is offline
Default My old pump gas Combination
Back in 2007 I’ll post the dyno numbers then the flow sheet.
Old 07-10-2022, 04:42 PM
Gach's Avatar
Here’s heads flow sheet.
Old 07-10-2022, 05:37 PM
25stevem's Avatar
25stevem 25stevem is offline
Do you have the weather data from that pull?
Looks like a 7% correction factor!
I do stuff for reasons.
Old 07-10-2022, 05:45 PM
Gach's Avatar
Steve sorry I don’t.
Old 07-10-2022, 06:19 PM
Half-Inch Stud's Avatar
Great Hp at 5200, and well all across 4500-6500. What octane pump gas?
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 07-10-2022, 06:35 PM
Gach's Avatar
93 octane.
Old 07-10-2022, 07:49 PM
Stan Weiss's Avatar
Lou,
This looks somewhat like a dyno sheet you and I PMed about maybe a year and a half ago. Glad to see you finally found a more accurate version.
Stan
Pontiac Pump Gas List
Old 07-10-2022, 07:55 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is online now
What did the car run with that combo? If you don't mind sharing
Old 07-10-2022, 07:57 PM
Gach's Avatar
Those dyno numbers were with this unported Victor intake as you can see, the intake was just port match to the heads.
Old 07-10-2022, 08:01 PM
Gach's Avatar
I later change over to this fully port Victor intake, and it pick up close to 30 hp.
Old 07-10-2022, 08:07 PM
Gach's Avatar
First pass off the trailer it went 9.80 @ 136 mph. With 1.418…60’
Old 07-10-2022, 08:10 PM
Gach's Avatar
On rev limiter it kept saying Lou shift me..lol.
Old 07-10-2022, 08:30 PM
Gach's Avatar
Best pass was 9.45 @ 140.76 with 1.31…..60’ that’s with new intake.
Old 07-10-2022, 08:52 PM
Gach's Avatar
I posted this, to encourage guys that you can easily make 750-760 hp on pump gas with a Pontiac. with unported Victor intake. It’s not a big roller either, 264/276 @ .050 with 729 lift on a 112 lobe. Though closed exhaust. And for me perfectly street able. What street able is different for others
The Following 2 Users Say Thank You to Gach For This Useful Post:
Old 07-10-2022, 09:25 PM
Gach's Avatar
That pass was at Atco Pontiac race event, first picture is with Bob and Frank from Alpontiac John Langer, Scott Rex and Haffman standing in front of the car in staging Lane. Scott Rex was stage behind me ready to make his pass.
Old 07-10-2022, 09:30 PM
Gach's Avatar
That’s John Langer standing behind me staging area me getting ready to make next and best pass. 2008
Old 07-10-2022, 09:41 PM
Gach's Avatar
Tire again
Old 07-10-2022, 09:47 PM
PAUL K's Avatar
PAUL K PAUL K is offline
This is a great thread. Thanks for posting it Gach.
Here is a link with more details on this build's performance.
Post 26 talks about the intake manifold change.
https://forums.maxperformanceinc.com....php?t=649157&
Good reading for sure!
Go fast, see Elvis!
Old 07-10-2022, 10:45 PM
Gach's Avatar
Initially I was running 3” Dr Gas cross over with 3” mufflers
Old 07-10-2022, 10:48 PM
Gach's Avatar
Then I changed over to 2”-4” merge collector with 4” exhaust and 4” bola mufflers.
Closed Thread
