Is anyone running the Butler CCA-BP 8040 SP hydraulic roller 242 248 110lsa 540 563
lift cam
Just wondering? |
I have that cam on a 112 lsa in my 455. Using the Johnson short travel lifters. Have not dyno’d the engine yet but it sounds good.
1979 TA 541/T56 Magnum 1964 Catalina 462/TKO600 1965 GTO 389/4speed |
Due to time constraints not allowing for me to grind my profile, I will be running that grind, also ground on a 112 as previously mentioned, in a 400 based 462 with Edelbrock D-ports and FI Tech Fuel Injection in a customer's build i just started on.
It's a decent grind, the 110ls would come on a bit sooner, and definitely needs good compression. I will be running it with 1.6 Rockers. |
I ran it in my 400 before going solid roller. As long as the supporting cast is there (intake, heads, converter, gearing) it's great!
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
