Old 11-28-2022, 02:28 PM
Mike S's Avatar
Mike S Mike S is offline
Default windage tray for mild build ?
I am building a mild street 400 for the street car. The 400 had no windage tray from the factory. Should I look at installing one for a mild 400 build? I am thinking for $100 can't hurt but don't know if it would be a waste of money.
Old 11-28-2022, 02:32 PM
tom s tom s is offline
I think I would get a pan that has the sump built in to help contain the oil at the pump.Tom
Old 11-28-2022, 02:52 PM
ta man ta man is offline
Not worth the effort or cost. I don't even have one.
Old 11-28-2022, 03:07 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I would, especially on a street engine.... We always try to use them. The factory spent a lot of dough installing them on millions of engines.... I'm betting they did something positive. Pontiac "did things for a reason". They stopped using windage trays when cost cutting took precedence over quality.
Go fast, see Elvis!
The Following 5 Users Say Thank You to PAUL K For This Useful Post:
Old 11-28-2022, 04:50 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I don’t have one. But, I do run the Canton 15-400 pan that keeps the oil away from the crank. Even at 7 qts.
Old 11-28-2022, 05:19 PM
You need to check caps if they are even tapped for one
Old 11-29-2022, 11:50 AM
glenn911's Avatar
glenn911 glenn911 is offline
What year did they stop using them?
Old 11-29-2022, 12:26 PM
I use the same pan.
Old 11-29-2022, 12:28 PM
25stevem's Avatar
25stevem 25stevem is offline
I believe the factory stopped using them in mid 72 when the baffled oil pan became the standard.
The baffled pan was instagted by the handling that the Trans Ams where capable of.
I do stuff for reasons.
The Following User Says Thank You to 25stevem For This Useful Post:
Old 11-29-2022, 01:18 PM
The 1974 engines still had the windage trays, they stopped using them in 1975 from what I’ve seen.
Had ‘73 and ‘74 455s both equipped with trays. Also had a ‘75 455, no tray. All three were virgin not rebuilt.
All 3 engines had the baffled oil pan.
Old 11-29-2022, 02:20 PM
Steve C. Steve C. is offline
Pontiac Windage Tray & Oil Baffle Tech. Including dates and pictures within the link here.
https://www.gtoforum.com/threads/pon...e-tech.137776/
Similar information regarding production dates within the H-O Racing Pontiac book where it was stated "Pontiac has used windage trays on all their V-8's up though mid-1973".
( Information provided in this post does not represent any endorsement. And unless specified it is not based on personal experience and is offered for general interest only )
Note the comment and pictures regarding the full length tray was more prone to cracking. That happened to one I installed many years ago.
Old information here:
Old 11-29-2022, 02:35 PM
Here is a links on discussions regarding the factory trays cracking. These are only two of many such threads..
https://forums.maxperformanceinc.com...t=windage+tray
Old 11-29-2022, 02:56 PM
PunchT37's Avatar
I have a 74 YY 455 that doesn’t have a tray and a 73 YC 455 that does.
Old 11-29-2022, 02:59 PM
PunchT37's Avatar
Originally Posted by ta man View Post
I use the same pan.
Yep. I turn this thing to 6000 to 6300 on many occasions. No smoking or oil consumption.
Old 11-29-2022, 03:30 PM
Verdoro 68's Avatar
If your caps are tapped it seems like a no brainer to add one. Windage tray and/or a factory-style baffled pan are a baseline for any build IMO.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
Old 11-29-2022, 04:42 PM
PunchT37's Avatar
They don’t fit well with main studs. At least without mods.
Old 11-29-2022, 05:09 PM
Verdoro 68's Avatar
You’re right, unmodified they tray won’t clear. In my last build, the machine shop punched out holes in the stock tray to clear the studs. Butler sells a spacer kit that gives you clearance for main studs. I have them with the 3/4 length Tomahawk tray in my new build.
Ken
Old 11-29-2022, 09:44 PM
All the ‘72 engines I have torn down had windage trays installed. I believe Bart is correct: 1975.
Dr. Thomas Sowell
Old 11-29-2022, 10:32 PM
Mike S's Avatar
My engine was a 74 400 and had no windage tray. Caps are not drilled for one. Lower dipstick tube was bolted to the top of the center cap.
I was thinking of a windage tray that I used on the race car. It mounts between the pan and block.
https://www.summitracing.com/parts/c...8/make/pontiac
Old 11-29-2022, 10:46 PM
77 TRASHCAN's Avatar
Mike, using that tray, how is the pan gasket situated?
Shut it off
Shut it off
