After doing a little web research, it seems all Allison transmissions behind the Duramax engine, have the chebbie bolt pattern. This would indicate a 2006 or newer Allison transmission might be a good option. I'd rather swap the rear differential, the but that might not be as easy as it sounds.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
If the Allison Chevy bolt pattern is the same as the 350/400 bolt pattern then there are several adaptors available. Either with or without transmission mounted starters. Of course Bruce's comment about the 1/4 inch difference might require some research to pick the right adaptor. But if you used a 61 or later block (64 and later have block mounted starter) it would still look about the same as the 347 in the truck. Hardly anyone except a real Pontiac person can recognize the reverse flow cooling anyway.
You'd have to do a bunch of motor/tranny mount work as the early engine had 1 mount in the front and 2 mounts on the bell housing.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
The Poncho engine will be a 64 and later with a block mounted starter. At first I was thinking a 455 would be best, but I'm starting to lean towards a 400, or even a 350 two barrel. I guess I need to research rear ends that will bolt in. I don't think I need the added weight and low ratio of the one in it.
In my opinion a 455 would be best for such a large truck. The 455HO (now 467) in my Suburban is very pleasant (and fun) to drive. Weighing about 5,000 lb., the fuel economy is only 14 MPG but- it also got 14 towing a car home from Oklahoma! And it's happy on 87 octane.
Glad to see you "saving" that GMC. Are you on the oldgmctrucks forums?
