Old 12-05-2021, 02:03 PM
61-63's Avatar
61-63 61-63 is offline
Default Is anyone running the Butler CCA-BP 8040 SP hydraulic roller 242 248 110lsa 540 563
lift cam
Just wondering?
Old 12-05-2021, 02:43 PM
TransAm400 TransAm400 is offline
Originally Posted by 61-63 View Post
lift cam
Just wondering?
I have that cam on a 112 lsa in my 455. Using the Johnson short travel lifters. Have not dyno’d the engine yet but it sounds good.
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Old 12-05-2021, 05:30 PM
Vengeance Race Engines's Avatar
Vengeance Race Engines Vengeance Race Engines is offline
Due to time constraints not allowing for me to grind my profile, I will be running that grind, also ground on a 112 as previously mentioned, in a 400 based 462 with Edelbrock D-ports and FI Tech Fuel Injection in a customer's build i just started on.
It's a decent grind, the 110ls would come on a bit sooner, and definitely needs good compression. I will be running it with 1.6 Rockers.
Old 12-06-2021, 02:23 AM
krisr's Avatar
krisr krisr is offline
I ran it in my 400 before going solid roller. As long as the supporting cast is there (intake, heads, converter, gearing) it's great!
