Old 03-19-2020, 05:08 PM
einstein's Avatar
Default 69 Subframe measurement
If anyone has a frame loose, or even without the engine cradled, I'd like to confirm this measurement between the upper control arm mounts at 30 1/2 inches.
If I'm good, I plan to drill for the Guldstrand mods.
Thanks!
Old 03-19-2020, 06:24 PM
tom s tom s is online now
The engine is out of my 69,its on the top of the lift if I get it down tomorrow I will check it for you.Tom
Old 03-20-2020, 11:55 AM
694.1 694.1 is offline
Catch!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 03-20-2020, 06:50 PM
einstein's Avatar
Well now.... I suppose I might need to spread this frame somewhat, although an eighth-inch per side doesn't seem like much.
I still wouldn't mind getting real world measurements from a couple folks.
Decades ago I changed from bias/belted to radial tires and had to add offset shafts on the upper control arms to get the additional caster needed.
For all I know I could have had upper or lower control arms that were out of spec.
Old 03-20-2020, 07:37 PM
Never got the car down today.Went fishing.Tom
Old 03-20-2020, 09:26 PM
einstein's Avatar
Good call, Tom. No worries.
Old 03-20-2020, 10:50 PM
Firebob's Avatar
Firebob Firebob is offline
I plan on rolling the subframe under the body tomorrow. I'll measure what I have. Mines 67 though. Don't know if it matters.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 03-21-2020, 12:26 AM
einstein's Avatar
67 - 69 should same for all dimensions. Only differences I recall were a few holes.
Old 03-21-2020, 06:43 PM
Dick Boneske's Avatar
Not to hijack this thread, but is anyone familiar with frame sag under the engine. The alignment shop said they can't align our '68 because, even when taking all the alignment shims out, the camber was still off by a lot.
Can the problem be fixed without taking the fenders off?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 03-21-2020, 07:10 PM
Firebob's Avatar
I get 30" even between your measuring points. Seems like your frame may have spread a bit from the weight and the years.
Robert
Old 03-21-2020, 09:18 PM
einstein's Avatar
Actually, Firebob,, the spec sheet posted about by 694.1 shows the factory specification to be 30.75". I'm 1/4" under, you're 3/4" under.
I'm inclined to put my Porta-Power ram between and spread the frame a bit.
If somebody responds with a reading on a car with known good alignment we can assess further for more than just my car.
Old 03-21-2020, 09:26 PM
einstein's Avatar
Dick, with all shims removed, I'd think your camber is still too far negative? And where does that put your caster? Factory spec is only 1/2°, but that was for bias tires. You'll need at least 2.5° for radial tires or the car will be hard to handle, wandering a lot.
You may be able to use offset shafts like I used so many years ago. I'll see if I can get hands on mine to get you pictures. You can turn them either way.
Old 03-22-2020, 12:22 PM
Firebob's Avatar
Yeah after I posted that I started thinking that maybe yours more correct than mine. I guess I assumed that if the frame were going to do anything it would spread, not narrow, but maybe that's not the case. I guess my thought was as the frame got wider the motor mounts would widen and allow the motor to sit lower in the saddle as many do. I'm not sure if this is true or the opposite. The measure of the UCA mounting ears may not have any effect on motor location.
As far as the G-mod...here's my thing.
I did it years ago to the 69 and it seemed like I was going to need to cut down the mounting ears for clearance after. I ended up doing just a bit of grinding instead. Just enough so everything would freely move without rubbing or hitting. Then after a few years I had to change things and ended up going to taller upper ball joints that then required to go back to the original mounting position( you can't run both together) so I was glad I didn't cut anything off. If it were me, I would just go with taller ball joints instead of weakening that upper mounting area.
Robert
Old 04-07-2020, 12:44 AM
sprint6ohc's Avatar
sprint6ohc sprint6ohc is offline
Late to the party here. Thanks Dick for leaving me know about this. I had my frame (68) blasted and in the middle of cleaning up the welds. Good Lord the spatter and porosity !!! That being said I measured mine to be at 30 9/16. I have the OHC SPRINT= less weight less chance of sag?
Old 04-07-2020, 09:24 AM
einstein's Avatar
My convertible is also a Sprint. When Dad bought the car in '75, the left motor mount bolts were broken off in the block. Our first clue came while on the test drive, the 3-speed shifter was hitting left side of console bucket. I don't know how long the previous owner left it like that, and if that placed much load on top of the crossmember to stress it.
Thanks for the feedback.
