Old 09-20-2019, 02:57 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Originally Posted by ta man View Post
Finally heading for a track outing Saturday, it has been a busy year with life's commitments.
Only real change is the convertor..I swapped the Continental 10 3200 for a UCC 10 inch 3800/4000. At the moment I'm not sure on the exact flash stall. I also planned on swapping my gearing to 3.42's...but after driving with the new convertor..it really feels about the same on the street. So I left the gearing alone.
I'm hoping with traction to pick up a bit of 60ft time ..but at the same time hoping the top end mph stays the same and doesn't suffer with the slightly looser convertor.
Good luck! Thanks for the update.
Go fast, see Elvis!
  #222
Old 10-22-2019, 05:55 PM
ta man ta man is offline
Well I never made it on the planned Saturday. I finally made it last Sunday to TMP in Cayuga..first time there.
Only made one pass..my fuel pump was acting up and I believe caused the lack lustre performance.
Personal "worst" with full traction 7.171 1/8 th mile/95.71 11.300 at 118.80 1.614 60ft...well off by 5 tenths and 7 mph what it should run.
Even with the car running like crap I had some people stopping by telling me how quick it was. The cool part about this track is the return road runs in front of the grandstand...so you actually see spectators giving you the thumbs up as you drive by.
I'm heading back down this weekend with a new pump for redemption..I can't stand running slow.
  #223
Old 10-22-2019, 06:27 PM
tooski tooski is offline
11.300 at 118.80
11.30/118.8 and slow.
Well., I think that's funny right there. I'm hoping to get in the high 11's if I ever get to the track.
Maybe you should have said 'slower than what it should/expected.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
  #224
Old 10-22-2019, 08:11 PM
Tom Vaught's Avatar
Boost Engineer
Very Nice work there ta man.
Pulling for you to do a sub 11 second pass with your latest parts soon.
Chit fails. So how many hundreds of passes did you have on the other fuel pump and what kind was it?
Tom V.
  #225
Old 10-22-2019, 09:53 PM
It had quite a few passes on it, but a lot of street miles. It's was a Mallory 140. I ran it deadheaded which I think killed it over time..I need to put a return on the new one in winter and use my return regulator to make it last longer.
The car normally runs sub 10's 10.8 /125 give or take..that's why this was disappointing. It felt flat..and actually died after the stripe...
  #226
Old 10-22-2019, 10:55 PM
77 TRASHCAN's Avatar
That's too funny...11.30's a major subpar performance...LOL
If you remember, take some pictures of your fuel system, when You are under the car..
Thanks Jeff
Shut it off
Shut it off
  #227
Old 10-23-2019, 08:54 AM
Steve C. Steve C. is online now
Pure speculation on my part, but a comment regarding a lot of street miles with the fuel pump. A good tech article suggested electric pumps with huge gallon-per-hour numbers for race applications are often not always rated for continuous duty and can fail on a daily driver.
Old information here:
  #228
Old 10-23-2019, 10:48 AM
Formulajones's Avatar
Yep. I've run the same Mallory 140 on my chevelle for a couple of decades now. Mine utilizes a return line. Was going to the track with it 2-3 times a year but it was primarily street driven 2-3 days a week. I've been rebuilding the pump every 4-5 years with that driving routine. Like clock work it would die. I've rebuilt the pump 3 times, and the last 2-3 years the car has been doing a lot of sitting, but wouldn't be long with some driving it will start acting up and due for another rebuild. I can usually tell it starts sounding funny, and it's there.
So this week I ordered a Tanks Inc setup for it, 400 lph in tank pump, new 1/2" feed and return lines etc....
I'm finally ditching that daggum Mallory.
  #229
Old 10-23-2019, 12:30 PM
How does one install the Tanks Inc pump in an old tank? Do you need an adapter or a plate or make a new hole?
  #230
Old 10-23-2019, 01:28 PM
78w72 78w72 is offline
tanksinc sells just the pump & baffle module to retrofit into an older tank. based on the install videos they have & articles ive read about the install the pump has a template or just uses the mounting ring as a template for install. for a couple hundred bucks more you can just get the complete tank/pump set up & bolt it in. then maybe sell your old tank. thats what im debating on doing since i dont really want the hassle of drilling a hole in a tank with fuel in it. keep in mind, tanksinc & others say you still need 1/2 tank for drag racing at your level with good traction....
https://www.tanksinc.com/index.cfm/p...prod/prd84.htm
there are also other companies offering a drop in pump module, aeromotive has a nice one that uses a foam ring like in fuel cells as a baffle.
  #231
Old 10-23-2019, 02:43 PM
I just buy the tank and all. Makes things pretty easy that way and they are relatively inexpensive. Comes with a notched sump for the sending unit and pump so there is room when installed against the trunk floor, it's baffled and ready to go, powder coated for that price too.
I've done a few of these setups and they have worked flawlessly. Dad has had this setup in his GTO for 5-6 years now as well.
I don't know why I've waited this long to do my own car, lol.
  #232
Old 10-23-2019, 02:57 PM
GTO JONES's Avatar
GTO JONES GTO JONES is online now
I wouldn't bother doing that, get the tanks inc and be done with it. Well worth the money. A friend had one blow up on him lol.
  #233
Old 10-23-2019, 03:10 PM
You talking about Andy?
He weighs about 350 lbs and that tank knocked him on his a$$ about 20 feet down the driveway
Always a risky deal. The new tanks from Tank Inc are nice, and since they haven't had fuel in them you can modify easily without fear. I usually add the evap connections to them when necessary, as I'll be doing on this new unit as well.
  #234
Old 10-23-2019, 03:14 PM
GTO JONES's Avatar
Yeap
  #235
Old 10-23-2019, 03:44 PM
surfsama's Avatar
surfsama surfsama is offline
Just throwing another option out there. I use the gen I system and it works well.
https://www.robbmcperformance.com/pr...owersurge.html
Only a pawn in game of life.
  #236
Old 10-23-2019, 03:50 PM
Thanks..I will see how the Mallory lasts with the return setup. The Tanks Inc is a nice setup.. and very cost effective.
  #237
Old 10-23-2019, 06:55 PM
GTO FIREHAWK JOHN's Avatar
GTO FIREHAWK JOHN GTO FIREHAWK JOHN is offline
I have run the HP 150 at 10.60,s and it's been great & it's deadheaded with no return! It's all coming out next week when my EFI is all done. Let me know if you need a better pump! I used to have the Mallory 140 before. I have the tanks inc for mine now with the whole set up. Very clean & tidy. If it gets completed in time we will be there at Cayuga dialling in. My tuner says I'll get 70-80 lbs torque gain with the coil on plugs! I hope it's true.
John
1970 GTO Judge. New times 10.60/126 with a 1.45 60ft.
2002 FIREHAWK-conv. 6-sd.
1969 Carousel red Judge Ram Air IV
722 heads. 4-sd. Black interior.
  #238
Old 10-23-2019, 07:13 PM
John
Sounds good..how long does Cayuga usually run..till it snows? 70 to 80 ft/lbs seems a little optimistic..? I m either going this friday or Saturday depends on weather.
  #239
Old 10-23-2019, 08:12 PM
John
I hope you see gains...the old adage "The best laid plans of mice and men..."
So if you lose 1/2 a second...
Shut it off
Shut it off
  #240
Old 10-23-2019, 08:53 PM
cnc's Avatar
cnc cnc is offline
Good to see u got out agin Ernie...to bad about the pump issue though.....something I'll toss in on the Tanks inc set up ....
I bought the tanks inc setup and installed it in my 73 .....works great
I bought the insert to weld into the tank to get the pump assembly lower into the tank for clearance ....hindsight ...for additional cost Leaks at the weld after it was welded by a reputable welder And the pissin around I wish I bought there tank already to go.....but is what it is.....
Oh and I wish I was a slow as u. On those runs.....lol
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
