#161
Which lane were you in?
Last year they had the bugs/cobwebs or something in one side. Bader wasn't there? Would have talked to him. But being last race probably not much sense to it.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
#162
What do ya mean by last race ? Does Bader still own the track ?
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
#163
As for Bader, thought he still owned the track? And yes it was dragonflies, forgot that. Knew a couple other racers that were bitten.
#164
I noticed after the Boss Bird pass on Sunday back in the pits that they they had splattered some creature to the front bumper. Looked like it was pretty good size, possibly a dragn fly.
Matt 70 GTO 400 4-speed "Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge |
#165
Yep! May as well get a whoopin by all 3 of you!! Looking forward to it one of these days.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
#166
This also happened to my opponent on Saturday in round one. His run was about 2 tenths off. They did make us rerun. Luckily, I came out on top both runs.
Greg Weigart IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/6.21@110.47/9.77@137.08 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 |
#167
Can you post the et slips?
This can usually be shown, if it is the timing system. I have seen this happen and usually it's a problem with the timing system. (some of it may be grounding issues or electrical interferences)
#168
Congrats George!
Thanks for stopping to say 'hello'.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
#169
These are my 2 passes from Saturday's second round. I was in the left lane. See any difference in the right lane times?
#170
Sorry, only one pic per post?
#171
am curious to know- What would be ones guess as to the percentage of non Pontiac V8/Tempest 4 powered vehicles over the weekend? on the race side? and on the show side?
50% non Pontiac powered? or? thanks
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
#172
The only thing "unprofessional" about this well-orchestrated crew is their lack of a payroll.
And this deserves to be told- that this busy crew graciously took on the added burden of tutoring a rookie, by being my crew to test-run the lakester (all of 182 c.i.!) at Norwalk 2019. An invaluable opportunity and I can't thank them enough.
#173
You guys look like true professionals out there! |
#175
Lou Greco also was int he tower at the same time i was due to breaking out by over a tenth, i do not htink they rer-an that race, but i was busy packing up by then.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
#176
Do you guys the time slips texted to your phone?
#177
That 1st pic is definitely messed up.
They couldn't see that when shown it? On that 'slip' is that the way it is actually given out now? The 'First' should be who got to the finish line first. That should have been a big clue. The MOV shown is the biggest clue from the pic. .3051 MOV is like 55 feet, was that the distance between you 2 at finish line? (I show about 3 feet) With the reaction time that far off from a normal RT, should be another good clue. Usually, for whatever reason, the timer doesn't start when it should. So the .326 RT minus the 'normal' RT is the amount of error or delay of the timer start. Say .326 - .003 (from other ticket) = .323 timer delay. If you notice the MPH are actual because they don't use the starting line timer. But since you had a .323 second head start basically the ET incrementals will be quicker than they should be. Add the .323 to the final ET and that is what the ET would have been actually. (with a .003 lite) Try using this calculator: MOV Calc
#178
It's an app for your phone. It's called Race SMP. It keeps your last 50 runs. You just search for your car number. You can also search other car numbers to see how your friends runs went. It also has weather and DA but they were using corrected barometer to figure DA.
#179
Here are the actual time slips from my second round and the rerun they had us do. I was left lane. The next day, the timers screwed up when I was in the right lane. I didn't get a rerun (like many others with the same issue).
#180
Congrats to Ken and Kimberly, great people!!!
Bob and Keri,
"Artificial intelligence is no match for natural stupidity". 1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph 1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph |
