#141
Thanks. I haven't opened the package to my Lokar throttle cable yet since I'm still using the factory piece. I purchased a Lokar kickdown switch and the required bracket isn't compatible with the factory cable, which led me to the Lokar throttle cable.
Based on your description, I have to get aquainted with the pedal mechanism in my bird cause I can't picture it. It's difficult for me to envision how that replaced the clevis clamp? BTW, do the ferrules come with the throttle cable kit?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
#142
On the top of your gas pedal is a SLOT that the stock cable with a "ferrule" (that looks like a lead fishing shot weight.) slides into. On the LOKAR it had that removable Clevis pin. I just unscrewed that clevis from the Lokar cable, and slid the washers on and the pinched the Lead weight "Ferrule" on. Then I pinched the slot together to keep the cable from ever sliding up and out.
Here' a picture I found on ebay of a pedal rod (with out the gas pedal on it.) See the hole and slot? I then used the Ferrule as I described. You may not need to depending on your Throttle linkage on your carb.
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
#143
I see now that you're in a '69 bird.. I think the rod functions the same though. It looks the same, I think.
I'm in a 75.
#144
#145
Yes sir. That's it. I removed the fancy Clevis, it screws off with a tiny set screw. And used that at the other end. Then I copied the stock cable with a lead shot Ferrule.
#146
I have no experience with ferrueles, will they stay put with no soldering? I take it you had to buy them at a hardware store (that is, they didn't come with the cable)?
#147
You just crimp these on really hard.. here is a page that has some. I got mine at the hardware store. No soldering necessary.
http://www.fdsons.com/wire-cable-cab...9_881_887.html
#148
Thanks again!
#149
#150
The kickdown works sweet; stomping it at 30mph breaks the tires loose nicely! At 20mph, It goes sideways-fun but scary! I wonder how it would feel with 3.42's and a 2500 converter?
#151
Awesome.
I still haven't hooked up my Kickdown.. Lokar makes good stuff. I'm interested and it'd be helpful for reference to see pictures of how your throttle arm attached to the cable. Also, how you attached the pedal arm? Did you actually use the clevis fastener that came with the cable? I dont know how you could do that neatly. I'll take some pictures of my Pedal end.
#152
I'll take pictures when I get a chance and post.
#153
Although the throttle stud isn't a "ball" the Lokar throttle cable cable clip snaps on to it and will not come off unless I pry it off. Basically, it snaps on to the stud the way it would if it was a ball stud:
#154
Interesting! I was going to look for tap sizes and to the clevis mod to mine. On the pedal side I just cut the stock cable and slide the lokar end out the clevis then used the stock black clip and slid the cable. The Lokar comes with a big enough furrel looking like thing on the end that it works fine. I was going to cut the stock pin off but then realized the bolt\nut would hit the arm behind it. I'll see if my Lokar end attaches as well that would be sweet.
Just in case it doesn't do you remember what size tap you used? 5/16 Fine? What size drill did you use before, I've never really had to tap anything before... One downside of cutting the stock cable is now I need to get this working with the Lokar stuff no matter what
1973 Firebird, Formula hood, 466 roller cam, ported heads, T56, Hotchkis springs, Koni shocks, DSE Subframe connecters, PTFB upper a arms, re-enforced lowers with global west delrim bushings, C5 brakes front and rear, 18 inch Boss 338 wheels, 4th gen TA power seats seats, Morris seatbelts, hydrotech hydroboost, speed hut gauges 1973 Formula 4spd long term project |
#155
Thanks for the Pics Will. That's interesting. Not like my pedal at all. Birds and Goats must be different!
I dont recall the size of the tap..Looking at the photos I'm guessing it was a 5/16. See how that fits in the clevis.
#156
I did the Will method and its not going anywhere. Thanks for all the tips on here the Lokar piece is now installed and working wonderfully!!
#157
I think the Lokar carb end was made for that carb linkage so that is a nice fit. Mine was different. The Lokar cable is nice.
