THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
#121
Just got mine looks great!! Thanks to all involved!!
#122
Received and greatly impressed. Thanks for getting this done.
#123
FWIW the carb spacing is 3 9/16" apart front end stud to rear front stud so will check Holley spacing if 4160s will fit.
#124
Got mine today.
Amazing! Awesome casting and machine work. Very grateful to all involved in this project. All the hard work has paid off. Thank you!
" Darksiders Rule "
The Following User Says Thank You to misterp266 For This Useful Post: | ||
#125
Pictures of Holleys on adapters, if you want that option.
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
#126
Are those just standard adapters? No mods for this intake? I have a pair of 660’s I thought about using. Looks good.
Actually, with no secondary metering plate, 660’s would fit no problem…..
" Darksiders Rule "
#127
Standard adapters, 660s will need a little more spacer height for the mechanical throttle linkage they use, I have a pair I tired before I put these 715s on. As their linkage spins that big arm will hit. Regular vacuum secondary and probably DPs usual linkage will clear. The ones I put on I had trimmed the bottom tab off back in 1971 to clear my 409 manifold with them sideways. Recolored and freshened a couple of years ago by Sean at SMI.
#128
Center hung bowls are just a hair too long.
#129
Couldn’t resist setting my blower carbs on it. No adapters but ya, it would work! Probably never fit under a hood though.
" Darksiders Rule "
#130
These 2x4 Carter's would l@@k awsome on one of those intakes!!
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
#131
Received my intake on Friday. Installing it on our 62 Royal Replica. Replacing the S&K tunnel ram. Making this car more Super Dutyish under the hood. My goal is to run a few NSS with SEGA and NSS at Norwalk next year.
#132
Received my manifold on Friday! Awesome piece! Thanks again!
69 Judge RAIII 4SP 2ND OWNER 63 Catalina 421HO 4sp 73 Trans Am 455 4sp http://www.sdperformance.com/ Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds. |
#133
I received my new intake and just wanted to say thanks to Tom and everyone for there effort. GREAT JOB!!!!!
#134
I think I'm late to the game here. I am interested in one of your late model intakes if you have any more available please let me know. Thank you
#135
PM sent.Tom
#136
I thought I would provide a little fitment information on the new bathtub intake into a 62 Catalina. So this is a late model intake fit into a 62 Catalina with a flat, stock hood. This intake has 1/2" spacers and a thin gasket on each side of the spacer. the AFB carburetors are genuine Carter units, 750 CFM with the large diameter air horns. {shorter carbs) With the hood installed and closed, there is approx. 3/4" clearance at the rear carb to the hood and slightly less for the front carb. ( probably about 5/8"). There is NO ROOM for a proper air cleaner of any type. As Tom S has suggested, I am going to install the Ram Air spark arrestor screens over the carbs to keep gravel and large crap out of them. This will be a temporary solution. Future plans call for the factory metal hood scoop being installed for proper clearance and more room to allow air into the carbs. My experience, at least on the dyno, is this manifold is not a happy camper with the carbs directly bolted to the manifold top. But that would gain 1/2" additional clearance. Hope this fitment info helps anyone running one in a Catalina, Grand Prix, or Bonneville.
The Following 3 Users Say Thank You to mgarblik For This Useful Post: | ||
#137
Sold out!Tom
